Question about NetGear WG111 802.11g/b Wireless Adapter
The netgear program says that I am connected but my comp says its an "unidentified network"
  • 33 Answers
If it says Unidentified N/w, Means u have Typed wrong Password
Or else Jus try to Restart the Computer and once again Connect to Wireless
all the Best................
Posted on Oct 06, 2010
I have a Netgear XET1001 and when i pluged both adapters in cannot always connect to the internet. Sometimes it connects with no problems and other times i recieve "Unidentified Network, No Internet...
It's most likely Windows 7 cannot acquire an IP address from the network.
I suggest, when the connection is OK, you go to Start -> All programs -> Accessories -> Command prompt (Or hold the Windows key and press R then type "cmd" without the quotes and hit Enter)
In the command prompt, type ipconfig /all (a space before the / but none after).
Note down the following information :
IP address IPv4 (it should be something like 192.168.0.3 or 192.168.1.3),
Subnet mask (Generally it is 255.255.255.0),
Default Gateway (The first three digits will be like the IP address);
Close the Command prompt to tidy the screen up a bit.
Once done, right click on the Network icon in the Icon tray, and click on Open the Network and Sharing Center.
You should have a link named "Local area connection". Click on it then click on Properties. You should see a list in which there is "Internet Protocole version 4"
Make a double-click on the text "Internet Protocole version 4"
Choose the option "Use the following IP address" and enter the information as you have noted it before (IP Address, subnet mask, Default gateway).
You will notice that it will ask you for DNS servers. In the first one, enter the values for the Default Gateway. Click "OK", "OK", "Close"
May 12, 2011 | NetGear Powerline Network Xet1001...
Can't connect to the internet using Vista OS on Compaq laptop. Using a WNDR3400-100NAS Netgear router. It finds the router and it labels it as an unidentified network and it will not complete the...
I am assuming you HAVE connected before.
Here is how to fix that corrupted DNS cache in vista.
1. Click the Microsoft Vista Start logo in the bottom left corner of the screen
2. Click All Programs
3. Click Accessories
4. RIGHT-click on Command Prompt
5. Select Run As Administrator
6. In the command window type the following and then hit enter: ipconfig /flushdns
7. You will see the following confirmation:
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
After that in the same command window type
ipconfig /release
ipconfig /renew
That should clear up the issue. Odds are you were sharing an IP address with someone else on the network.
Mar 24, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I just got a NETGEAR n600 dual band router, ran the resource cd to set up the network, and everything was successful. Whenever i connect to the wireless network my computer says its connected to an...
My Friend ,
Seems that the router is producing the wireless signal the problem is only with the computer.
What i can suggest you is to delete all the wireless networks from the list and then try to add the network again.
Dec 09, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
I have an hp comp that wont connect to my netgear internet access
Define/explain "wont connect".
Are you trying to use an Ethernet cable to connect the two devices? If so, try a different cable, to rule-out a "bad" cable.
Do you have any software like "Norton Internet Security" on the HP? It is notorious for "blocking" attempts to connect to "unknown" networks.
Does your desktop computer have a wireless networking adapter that you are trying to configure/use?
Will any other computer, either via Ethernet cable or wirelessly, connect to the NetGear router? If not, then maybe the NetGear is the problem.
Any error-messages when you try to "connect" ??
Exact wording?
Sep 07, 2010 | Computers & Internet
WIRELESS PROBLEMS
Well it should work on all the computers.
There might be some problem with the wireless connection.
You said the wireless works on all the other computers . that means the wireless router is working fine.
If your wireless network is secured then make sure that you have the correct network key / password.
Check the IP address on your wireless computer . Is there any static IP address on the computer.
Click Here
for step by step instructions
Mar 09, 2010 | NetGear WGU624 Router
New mini computer says"acquiring network address" shows contected to netgear but won't access the internet
It means your router dhcp is not running proeprly.
You can set ip addreses manually.
for that go to my network places proeprty then you see your network adapter right click on it then go t oit's property then tcp ip .
Set ip addreses , subnet mask and gateway.
set your ip addreses if your router ip is 192.168.1.1 then you can set your computer ip is 192.168.1.2
subnetmask as 255.255.255.0
and set gateway as your router ip means 192.168.1.1
you can access your router with default link
http://192.168.1.1
or http://192.168.0.1
type user name a s"admin" and password as "admin" or blank or "password"
then check its ip and settings.
Aug 08, 2009 | NetGear WGT624 Wireless Router
Unable to connect to wireless network
Re-Enter your wireless key correctly is normally what thats means
Mar 15, 2009 | NetGear WG311T 802.11g/b Wireless Adapter
Netgear WG111 Wireless 54Mbps USB Adaptor cant connect to the network
dont remember what my security key or passphrase is comp went down and wiped it out had reinsal can you help me
Oct 22, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Linksys Wireless-N pci adapter model wmp300n
If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
May 25, 2008 | Linksys WMP300N Pre-802.11n Wireless...
NetGear WG111 802.11g/b Wireless Adapter Logo
239 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
