Internet I have a 4 year old computer which is connected to broadband internet I also have a 5 year old laptop in another room. Can I get something to transfer the internet to my laptop? A friend suggested a dongle-whatever that is. Can you help
  • 77 Answers
There are a few ways you can use wireless to get the laptop online. The easiest way would to buy 1. Wireless Router and 2. Wireless USB Adapter. Follow link for some pretty good instructions to setup a home wireless network.
http://lifehacker.com/software/wifi/geek-to-live-set-up-a-home-wireless-network-162754.php
Chris
Posted on May 28, 2008
I have a Toshiba Satellite L305D-S5934 notebook with Windows Vista Home Premium. I use Verizon wireless broadband to access the Internet. I can connect to the internet using their USB modems just fine, but...
You didnt mention via cord(Lan Cable)have you ever used it? is it works?
Ok let assumed the cord can access the internet.
1.Enter your device manager
2.locate Network Adapter >> there should be 2 or 3 network adapter type
3.If you found any question mark with yellow colour >> right click on it >>> update driver
4.toshiba has application built in called zero configuration >>> open it, and try setting something matched with are you looking for ( sometimes the program stuck on something else network adapter eg. LAN cord or built in Wifi
akee_akee@live.com
Aug 17, 2011 | Toshiba Satellite A135-S4487 Notebook
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    I have bsnl broadband connection; i am using a desktop to connect the internet,but i cant able to connect other laptop with wifi. i need bellow things with step by step instruction: 1.connecting one...
    Your router has an lan address or IP. Something like 192.168.1.1. This is what you must connect to. Each of the machines you want to connect must have (in this example) an IP number between 192.168.1.2 and 192.168.1.225. As long as your machines all have a unique IP they should all connect to your router. Your modem will have a gateway and typically this will be something like 10.0.0.1. So setup for one machine may look like this [192.168.1.3 subnet 255.255.255.0
    To find these setting, click on your lan connection, select "properties" and choose "Internet Protocol TCP/IP". Here you will see these settings. Your router guide will give you these settings, make sure you get them from your router guide.
    Mar 11, 2010 | Computers & Internet
    Connecting on internet
    it is almost impossible. One laptop may use a connection at a time. Otherwise it gets complected. The internet won't work as fast, and so on.
    Dec 13, 2008 | Computers & Internet
    Setting Up a Wireless Network
    You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
    1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
    2. Press and hold reset at the back of the router for about 15 seconds.
    3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
    4. Power on modem and wait for the lights to be ready.
    5. When modem lights are on, turn on router.
    6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
    7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
    8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
    9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
    10. Once you are successfully connected, check Internet.
    Hope this helps!
    Nov 16, 2008 | Linksys Wireless-G Broadband Router
    Installed orange broadband speed touch330 on to toshiba l300 series laptop now internet explorer does not open and and when it occasionaly did the page stopped responding
    Check your internet connection with another computer...there aslo can problems in windows (ex:-OS installation 6 5 months old)
    May 10, 2008 | Computers & Internet
    Wireless Internet
    yes you can purchase the router
    satellite?blobcol=urldata&blobheadername1=content-type&blobheadername2=content-disposition&blobheadervalue1=image%2fjpeg&blobheadervalue2=inline%3b+filename%3dwrt54g.jpg&blobkey=id&blobtable=mungoblobs&blobwhere=1193783379233&ssbinary=true
    • All-in-one Internet-sharing Router, 4-port Switch, and Wireless-G (802.11g) Access Point
    • Shares a single Internet connection and other resources with Ethernet wired and Wireless-G clients
    • Wireless data rates up to 54Mbps -- 5 times as fast as Wireless-B (802.11b), but also interoperable with Wireless-B devices (at 11Mbps)
    • Advanced security: Wi-Fi Protected Access™ (WPA), wireless MAC address filtering, powerful SPI firewall
    May 02, 2008 | Dell Inspiron 6400 Notebook
    Connecting my laptop wirelessly to internet
    Make sure that all the network connection settings on your new computer are the same as your old computer. Also, does it show you are connected to your network?
    Mar 26, 2008 | Computers & Internet
    Computers & Internet Logo
    111 people viewed this question
    David Payne
    David Payne
