Question about DCS 36-6-1 Gas Kitchen Range
What do need to covert to lp gas and where do i get parts to do so
How do I convert from liquid propane to natural gas
You need parts from the manufacturer. The gas orifices are different sizes between natural gas and LP gas. If you try natural gas with an LP gas orifice, you will not get much flame. If you use LP gas with a natural gas orifice, you will burn off your eyebrows and possibly other things.
Dec 19, 2013 | Capital Cooking Titanium X CCE26XRBI (NG)...
I brougt glowarm space heater model HDB30PT for propane gas but I needed a natural gas space heater.Can I covert it to natural gas and how can do it for me
I'm sorry to report there is no gas conversion for your DESA heater. In fact, no vent-free (vent-less) gas heating appliance (that includes gas log sets) is approved to be converted from one gas type to another. If you bought it from a retail store, exchange it for a LP Gas Model or a refund.
Hope this answered your question and thanks for choosing FixYa.
Sep 20, 2011 | Desa International GWP20T GLOWARM Wall...
I have a Weber Silver B grill that I purchased 12 years ago.I would like to convert it from propane to Natural Gas. I have been told I cant! Is this true? If not, where can I get a conversion kit? Thanks!
Weber stopped selling conversion kits due to some legal action in 2008. There are no longer kits available. What you would have to do to covert it is order a replacement gas valve for the NG version of your grill just to get the orifices. Then you have to replace the LP regulator with a NG regulator. Typically most NG grills do NOT have a regulator but local building codes will require a NG regulator and a different gas line hose.
Conversion of a BBQ gas valve to NG is a matter of drilling out the orifice to a larger hole in an LP orifice.
You will not find anyone that will perform this conversion for you due to legal liabilites.
If you want to convert it... you will either have to order the whole gas control valve for NG or drill out the orifices yourself in your current gas valve hoping your got the orifice hole size correct when you drilled it. Mind you all liability for doing this lies solely with you.
This site has all weber parts:
http://www.clagrills.com/allgrillparts/weber/weber-models.htm
http://www.clagrills.com/gasgrillparts/weber/weber-gas-grill-parts-home.htm
Thanks for choosing FixYa,
Kelly
Apr 29, 2011 | Weber Genesis Silver B Grill
We bought a ge eterna series and it is currently lp and i have natual gas can lp hook up be used or do i have to convert it i was told you could use it
NO!!!! The orfice is of different size and could cause an explosion it must be coverted over, sometimes the change over is located in the owners manual please follow the instructions or call a service repair.
Apr 09, 2011 | GE Dryers
Covert natural gas to propane new dryer dlgx2502v
inside the machine, right after the gas connection there is a coupling and inside is a small brass screw with threads on the outside. Youll need to unscrew it and turn it around and screw it in again. this will convert from natural to LP. See if you can find a technical manual online for your specific model number to find the exact placement as it varies from dryer to dryer.
Dec 16, 2009 | Dryers
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
What do I need to do to switch over from natural to LP gas?
You will need the following Castle part #s
17003A- Pilot head assy LP gas @ $49.
17006L-Convertible Press Regulator LP gas @$29.
Give Castle Stove a call @ 800-637-9188 to make sure that is all that you will need. They were the only two parts I found on there website (www.castlestove.con) under your model # for LP gas conversion. There might be a need for a conversion kit for the gas valve.
captrick
Jul 20, 2009 | Comstock-Castle 2616HG Deep Fryer
Coverting a Vulcan 260L commercial range to Propane
Yes you can convert to LP gas. go to this web site to get the parts.
http://www.vulcanhart.com/manuals/F-30536.pdf
Go to page 9 and look at parts # 57 - 60 that is the part you need to change. You need to know the sea level that you are at though so you get the right part.
Now if you go to page 8 you will find where it goes part # 53 thru 61
To order the parts go to this web site
http://www.vulcanhart.com/parts.cfm
If any ? please fill free to ask.
Dec 17, 2008 | Vulcan 260L Gas Kitchen Range
Switching from natural to lp gas
Hi, The gas jet is too large and the gas valve needs adapted for lp gas. Lp gas has more pressure so the jets are smaller. Any appliance parts store should have the kit needed to adapt the gas valve along with the jet. The valve pressure will also need to be adjusted using a cheap water column gage also available at the appliance parts store. Check with them on what the pressure needs to be in your area. If the regulator is part of the lp it should be set right. If it is part of the fryer, set up for natural gas, and there is no lp regulator, it will need to be adjusted and or replaced with an lp regulator. Gas companies are usually very helpful with such things because they are concerned about gas safety. Good luck.
Sep 23, 2006 | Cecilware GF-28 Deep Fryer
DCS 36-6-1 Gas Kitchen Range Logo
35 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
paulcarew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
