Question about Car Audio & Video
Hola tengo un amplificador audiobahn A2401X y se me quemó, tenia malos los 6 reguladores IRFZ44N y un IC GL 494 0025. se los cambie y me funciono bien, pero a los 15 minutos se me volvieron a quemar los 6 reguladores. si me pudieran ayudar se los agradeceria mucho.
zair
  • 82 Answers
SOURCE: help, please
Make sure all the ground screws are in place.
Posted on Mar 27, 2008
Benimur
  • 6966 Answers
SOURCE: benimur
To my understanding, on an Audi A4, error code P1392 indicates camshaft sensor circuit. This could be a faulty sensor the camshafts are not correctly timed. 90s Audis are not very common in my country but from what I can gather:
The mark for the crankshaft gear is on the cover you have to remove in order to get at the timing belt. The sprocket you may be having trouble with is the intermediate shaft (in front of the water pump) and I don't believe that one matters at all since it doesn't drive any of the cams. The intake cams are driven by a chain off of the exhaust cam shaft so only the exhaust cam is driven directly by the timing belt.
Additionally, you may benefit from the Audi A4 Service Manual and/or Audi A4 Cabriolet Workshop Manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 28, 2008
Aleixo
  • 19 Answers
SOURCE: I need to repair a tv philips LO1.1UAC-7638
Check the Video amplifier IC on CRT board. I'm sorry I can't write in espanhol. Try. Good l
Posted on Feb 19, 2009
  • 3940 Answers
SOURCE: tengo el mismo problema
Intente el booting al modo seguro, vea si usted puede conseguir en Windows. si usted puede, intentar un restablecimiento del sistema a una fecha anterior en que el sistema trabajó normalmente. Si usted no puede patear al modo seguro, no intenta el booting al CD de XP, no va a la consola de la recuperación, no funciona con el comando CHKDSK /P después no vea si el sistema patea normalmente. Si nada de ése ayuda, funcionar diagnósticos en el HDD y ver si se detectan algunas faltas. Si la impulsión falla, después substituya la impulsión.
En Engles
Try booting to the safe mode, see if you can get into Windows. if you can, try a system restore to an earlier date when the system worked normally. If you cannot boot to the safe mode, try booting to the XP CD, go to Recovery Console, run the command CHKDSK /P then see if the system will boot normally. If none of that helps, run diagnostics on the HDD and see if any failures are detected. If the drive fails, then replace the drive.
Posted on Jun 30, 2009
walesarumi
  • 6993 Answers
SOURCE: LA PANTALLA DE ESTEREO APARECE
please can you rephrase this question in English?
Bye for now.
Posted on Oct 07, 2010
Tengo problemas con mi HHR la luz del T/C no se apaga y cada vez que pongo el cambio en Reverse o Drive hace un golpe en el motor, como puedo solucionar el problema?
Hola, Tengo Una HHR Y Cada Vez Que Me Aparece El T/C Me Empieza A Dar Golpeteos En La Caja Cada Vez Que Meto Drive Y Al Avanzar Da El Golpeteo De 1 A 2 Despues De Esto Tambien Me Aparece El Check y Al Aparecer Esto Ya no Enciende Desde El Control Remoto Yme Gasta Un Poco Mas De Gasolina Me Han Dicho Varias Personas Que Son Los celenoides Y Tengo Esa Duda
Apr 13, 2012 | Chevrolet HHR Cars & Trucks
HOLA TENGO UNA MOTO PULSAR 180 Y DE REPENTE DEJO DE FUNCIONAR EL ENCENDIDO PROBE CON EL MAND CON EL RELYE DE ARRANQUE CON EL AUTOMATICO CAMBIE LA BATERIA CAMBIE LAS BOBINAS DEL MANGETO EL CDI EL REGULADOR...
Hola, Ulisespiango el siguiente se aplica a los modelos de combustible inyectado con carburador tambi?n, y los sospechosos habituales son: 1. severamente descargada o una bater?a da?ada, 9 voltios o m?s bajas. 2. defectuoso alternador / generador y regulador de voltaje o. 3. Los terminales de revisi?n de la bater?a en busca de da?os o corrosi?n, comprobar los cables de la bater?a en "ambos" extremos de conectores sueltos, corro?dos o rotos, "dentro" y fuera del haz de cables, realizar prueba de movimiento conector y comprobar los cables con un ?hmetro si es necesario. 4. Interruptor disyuntor o ignici?n principal defectuoso, compruebe si hay conexiones sueltas y continuidad. 5. base es defectuosa y o rel? de encendido, verifique la continuidad. 6. bobina de encendido defectuosa, el encendido / m?dulo electr?nico. 7. defectuoso CKP, CPS, CMP, MAP, TPS, O2, o sensores BAS, corro?do, pines del conector de alambre sueltas o rotas / z?calos. 8. Agua o suciedad en el sistema de combustible, carburador o filtro. 9.. Restringido, bloqueado o doblado la l?nea de combustible. 10. Dep?sito de combustible vac?o. 11. La tapa de la gasolina no est? ventilando correctamente o tanque de combustible sistema de ventilaci?n bloqueados. 12. Una bomba de combustible defectuosa, regulador de presi?n y el o los inyectores de combustible. 13. La l?nea de vac?o del colector de admisi?n al grifo roto, agrietado, o no conectado, l?nea de ventilaci?n del carburador enchufado. 14. Aguja y asiento pegado cerrado en el flotador. Para obtener m?s informaci?n acerca de su problema, por favor visite los siguientes sitios web. Buena suerte y buen d?a. DOWNLOAD Bajaj Pulsar 180
May 31, 2011 | Bajaj Pulsar 180 Motorcycles
Tengo una batidora y ya le cambie los carbones y no me funciona que puede ser
Hola LALOB_RO. Cuando cambió los cepillos (carbones), es posible que haya instalado uno o ambos de ellos para que los cepillos no encaja correctamente. Sólo hay un camino para que los cepillos que se ha instalado correctamente. La caracóncava del cepillo debe descansar por completo en el conmutador de la armadura. Siusted lo ha girado 90 grados demasiado, el cepillo no se asienta correctamente y elmotor no hay nada 'jugo'.
Le recomiendo la eliminación de los pinceles de nuevo para comprobar que ambosestén instaladas correctamente. La ilustración de arriba debe permitir volver a instalarlos pinceles con confianza. Buena suerte, espero que esto ayude. Howard, Burke, VA,EE.UU.
Si esta solución ha sido útil, por favor, valoren, gracias! - hslincoln
Feb 10, 2011 | KitchenAid K45SS Classic Stand Mixer
Hola a todos. Tengo dos problemas con mi jeep cherokee 1990. El primero es que me ha quemado dos headlight switch, se apagan las luces en cuarquier momento y despues no encienden y cuando verificamos...
Hola, Para el primer problema, es necesario instalar un Relay en el circuito de las Headlights, esto ayuda a evitar que el switch se queme, ya que sin este Relay, consume mucho amperaje y esto es la causa del switch quemado. Suerte!
Jan 29, 2011 | 1990 Jeep Cherokee Limited
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Dec 13, 2008 | Televison & Video
Help, please
Nov 02, 2007 | Sharp CD-SW200 CD Shelf System
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
