Question about RCA Computers & Internet
Tv only turns on sometimes... it makes the noise and the light comes on the power buttom but it shuts off after only a couple of seconds. then the green lights comes back on and shuts off.. does this a couple times then never turns the tv on.
    Sergeant:
    Champion:
  • 293 Answers
Loose connection on your CRT board in power supply section.Need for resolder..
Posted on Oct 06, 2010
Loses picture and shuts off and on
I once had an HDTV with a similar problem. If I turned it back on, it would make a loud BUZZ-BUZZ-Buzz noise for about twenty seconds before coming back on.
I can only guess that the problem is the TV drawing too much power from a circuit that can't support it. Do you have many electronics plugged into the same socket? Is the TV going into a splitter? Try isolating the connection and the TV might have better luck. No guarantees however.
If it's the same problem I had, then it will do this no matter what you hook up to it, as you seem to have at least partially discovered.
Jan 29, 2018 | Sony BRAVIA KDL-46XBR3 46 in. LCD HDTV
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
Tv shuts off and led power light blinks
Turn off/on couples times,power it well come back on stable,if not ur video board it dead.
Dec 17, 2009 | Sharp LC-32SB24U 32 in. LCD TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
Ringing noise coming from my philips 30PW9110D/37
This noise is coming from the power supply.
You may want to look for a local repair shop from this website to get service if desired.
If the power supply were to be replaced, it could be done by you if you are somewhat savvy.
Mar 31, 2008 | Televison & Video
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
Computers & Internet Logo
334 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
