Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer makes a clunking sound when running. - Frigidaire GLEQ2152ES Electric Dryer
  • Frigidaire Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Also check out...davesrepair.com for some installation video/pictures.
This is a FREE answer, Please rate me
Posted on Oct 06, 2010
3 Suggested Answers
  • 177 Answers
SOURCE: Whirlpool LER5620KQ1 - Dryer makes a clunking sound when running
It may be that one of the plastic pieces inside the trum has somthing under it. Coins of other things can get under them. You will have to tilt the top back so you can get to them. Unscrew 3 screws in each of them remove them and check them . Watch how you took it out so they can be put back just like they came out.
Take a putty knife and run it between the top and the front panel not far from the corner and push the two clips back one on each side. Raize the top up and brace it. Unhook the door switch take the two 5/16 screws out of the top of the front panel and pull the front panel toward you and lift it off the clips at the bottom. Put something under the front of the drum to hold it up while you take off the belt. On the right side reach under the drum and push the idler pully to the right and take the belt off the motor pully.Now you can take the drum and belt out. You could start the motor with the belt off and see if the motor is making the noise. Don't run too long. Now you can check the idler pully, the rollers the drum rides on in the back the felt on the front panel and the back of the drum. Also check the belt Be sure and mark how everything came off and put back just like it came off. Hope this helps
Posted on Jul 16, 2010
Testimonial: "Great feedback on my issue, had all the info I needed."
heatman101
  • 43501 Answers
SOURCE: My Atlantis dryer makes a clunking sound when
Hi, Belt is going bad... has a chunk out of it...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Feb 10, 2011
Frigedaire dryer front loader makes clunking noise
Hi kirst_alers2 - From what you have described it sounds like you either have a problem with the belt, front (and/or rear) bearing, or a loose connection with the motor or drum. Lint or something else clogging the vent could be causing the dryer to take a longer time to dry the clothing. If the dryer is taking too long to dry then the issue may lie with a faulty sensor. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replaced depending if they are worn, damaged or loose. You can often locate a qualified tech through the manufacturer website.
Apr 08, 2013 | Frigidaire Electric Dryer
Still turns after opening door
When the door is closed the switch will close, allowing power to circulate through the rest of the circuit. When the dryer door is open the switch will open, breaking electrical contact to the neutral connection of the circuit and stopping the flow of electricity. so it sounds like a bad dryer door switch.
Feb 02, 2012 | Frigidaire Dryers
The dryer made a clunk sound and the tumbler stop rotating
Sounds like you belt has either broke or came off. If you were rotating the drum by hand in the counter clockwise direction when it clunked, there is a pulley kit to fix that problem. If it was just running when it clunked the belt probably just broke. Hope that helps
Aug 29, 2011 | Samsung DV448AEE Electric Dryer
Jenn Air gas dryer makes a clunking sound when drying. Still heats and dries but want to stop the clunking. Any help would be appreciated. Thanks
thats because one of your tub bearings is weak or going out or the front guides are work that the tub runs on
Jan 14, 2010 | Dryers
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Gallery ser. front load makes loud clunking sound in all cycles
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Clunking sound on dryer
Remove the front panel and check the blower wheel attached to the motor.
It may need replacing.
Possibly lint and debris blocking it.
Feb 21, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer Making Lound Wobbling Noise
I'll bet the drum is cracked.
Jan 11, 2009 | Dryers
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
298 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
