Question about Kitchen Ranges
My evcon furnace is only 4 1/2 years old, model #GF9S080B12UP11H, Serial # W0L5117447. It won't start and I've already removed doors, turned off gas control switch, switched off the fuse, turned off the unit. I then waited and replaced doors turning the switch back on, turned on the fuse and the unit. It hummed and purred for a minute, something inside clicked on and it continued to hum, then the flashing light inside went from steady green to flashing red. I repeated the steps above and it did the same thing. I finally counted the red flashes and it's 7- indicating ignition lockout due to retries. How can I figure out why my furnace won't fire up? by the way- it worked a couple of weeks ago when we had a cold snap.
5 Suggested Answers
  • 124 Answers
SOURCE: Goodman U-30 Furnace
observe the sequence of operation. stat calls for heat and sends a signal, to furnace. check for 24 volts to common and white wire at furnace.first the forced draft motor starts and should have 120 volts to the plug it attaches to. after forced draft motor starts the pressure or vacuum switch closes should show no 24 volt when checked across terminals. shortly after the ignitor glows and shortly after click the main gas valve opens and main burners fire. shortly after the indoor fan comes on and hot air blows into the ductwork. follow the chain of events to see what doesnt happen and it is a clue to whats broke. maybe start by switching fan switch on stat to on. if fan comes on you have high and low voltage thereby eliminating the stat power and transformer as a problem. if you can see the ignitor look for it to be cracked . look close dont touch any part of it .it is powered by 120 volts when energized from board. dont forget when you take the door off there is no power to the furnace so be prepared to tape the safety switch closed when you are diagnosing.
Posted on Oct 24, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: My Intertherm, electric ignition furnace
That blinking yellow light is an error code. If you look behind the main cover there will be a wiring diagram and error code chart. This will give you an idea what the problem is.
Posted on Nov 07, 2008
dazzle37us
  • 17 Answers
SOURCE: GE Gas range won't work because "Door Locked" light won't go out
yes the locking lever needs to be replaced, and it also adviceable to still check the internal switch.
Posted on Aug 05, 2009
  • 5370 Answers
SOURCE: Maytag Gemini, Model MER6765BAW17, quit
H3 is shorted relay on control board and 133 is faulty control board.-----------In any case control panel board has to be replaced, ----------- Click this link, below.To order the parts:--
http://www.partselect.com/ModelFrames.aspx?ModelID=275629&ModelNum=MERH865RAW13&mfgModelNum=&ManufactureID=1&Selected=LYJICYOM&Position=2&mfg=Maytag&Type=&Mark=2 ---------- Part number 6 in the link is control coard.That has to be replaced.This will help.Thanks.Helpmech.
Posted on Jun 24, 2011
I WNEED TO REPLACE ELECTREC BOARD IN EVCON GAS ELEC FURNACE
You have picture capabilities... available...
Use them (nobody here is psychic).
There are a world of opportunities ... available to interface control boards with heaters... New & used
You model number does resolve to a REAL HEATER
EVCON FURNACE DGAH056BB5B.. but I have been unable to get it to RESOLVE to any CIRCUIT BOARD NUMBER.
In a case like this you should take
lots of pictures and notes ...
Draw out your schematic...
and MOST IMPORTANT
Get your OWN circuit BOARD number YOURSELF
(from your old board)... It is going to be a HONEYWELL, ROBERTSHAW or a similar manufacturer...
SIMPLY CANNOT BE DONE without you... or a REAL
repair person.
See sample boards...
Dec 28, 2016 | Heating & Cooling
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
Our coleman evcon furnace has started clicking over & over again before it starts up, we replaced the thermostat & the same thing happens.We are afraid that this is hard on the furnace & have resorted to...
Suspect that the igniter is causing the clicking (or could be a relay). Suggest having the furnace serviced. There is also a major recall for some models of the Coleman Evcon furnaces.
Oct 29, 2013 | Heating & Cooling
Coleman EVCON GAS FURNACE ugab075bua
Would need to have a serial number to determine.
Oct 13, 2013 | Coleman 7990-319p Evcon Gas Furnace...
For some reason the heater does not generate heat. the fan works but no heat. Any Ideas?
I've got an easy way for you to check, and then we can help you from there.
First pop open both lids to your furnace (this may require a screwdriver). Turn up your thermostat, push the safety interlock button in if it has one (it's a button that turns off the power when the doors are removed), and watch.
On most modern furnaces (past 20-25 years) you'll hear/see:
1. Inducer fan
2. orange glow (ignitor)
3. Gas valve opening and ignition (flames)
4. Main Fan.
that's normal heater operation.
The most common issue here is a burned out ignitor, in which case you wouldn't see the orange glow but the sequence would attempt to continue anyway (the gas valve will open and hiss gas, but it won't lite, then it'll give up and try again a few minutes later).
On older furnaces there's a pilot light to start with, the click of the gas valve and boom... ignition.
On new furnaces it's
Inducer fan
gas valve opening
spark - ignition
Main fan.
and there are some oddballs in between, particularly the Lennox Pulse. If that's your furnace just back away slowly and call a professional... some guys won't even touch those, so be sure to mention what it is... if you call a pro.
So go ahead and watch it run, then tell me/us what you see.
May 06, 2011 | Bionaire Heating & Cooling
How old is my Coleman Evcon Furnace, Modle Number: DGAT056BDE? I can't seem to find a Manufacturing date sticker. It was claimed to only be a year old, now living here a year it would now be 2 years old. ...
The Serial Number would really help in defining how old your Coleman furnace is. The model you have is used predominantly in manufactured housing. To find the Serial Number, you will need to remove the upper shroud of the furnace. There should be a sticker or plate on the back of that shroud of just inside the housing of the furnace, that will give you the Model # & Serial #. Armed with that, you can do a little detective work, as to it's age.
Mar 03, 2011 | Coleman Heating & Cooling
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Goodman furnace
you should not need the owners manual. most likely you will find a chart listing the diagnostic codes on the inside of the door to the blower compartment. diagnostics are printed next to the wiring schematic. the most common problem on this style furnace is just a dirty flame sensor. a small piece of fine grit sandpaper and a 1/4" nutdriver is needed. the sensor is located in front of the burner on either the far left or right. be carefull....(do not remove the hot surface ignitor that has two wires). you want the part that has only one wire connected to the sensor under the buner. pull it out and sand the dirt off of the metal rod. reinstall and enjoy your heat
Mar 22, 2009 | Goodman GMS90703BXA Heater
The repairman said there was excessive rust and the area was pitted near the heat exchanger. The furnace is a Coleman EVCON Model BGD12520 about 11 years old. Could this be residue from the burner or...
if he said there is rusted heat exchanger he was right not to start the unit . you can only call for a second opinion and have a nother repairman confure the heat exchanger is beyond its life. and then ask if there is replacement exchanger avalable for your furnace if its not to old this may be a less expensive alternative.
hope this helps you
please post fead back
Oct 20, 2008 | Heating & Cooling
Kitchen Ranges Logo
98 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
