Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Broken Shelves I have a frigidaire model #FRS6LR5EM2. Both bottom shelves have broken now and I have cracks in the top two shelves as well. I can find replacement parts just fine, but I have had this fridge less than two years. Are there any shelves made for this model that are built stronger or do I have to continue to keep buying shelves every few years? Thank you, Kim
  • 2 more comments
  • Anonymous May 29, 2008
    Same problem with Frigidaire FRS3R5EMB4..under 2 years old...two broken door shelf bins...tried gluing, but that didn't work long before failing. These bins should have been manufactured with more heavy duty materials. Sorry, no more Frigidaire refrigerators for me!
  • alesis Jul 03, 2008
    I have had the same issue: 2 of the side door shelves have broken. The meat tray drawer track and I see stress/cracking on the right hand wall of the unit.
  • heaths32 Oct 06, 2008
    I have the same refrigerator and the bottom door shelf broke, also.
  • akpedrob May 11, 2009
    Both bottom door (condiment) shelves have broken off. Does anyone else beside frigidaire make these shelves or at least compatible shelves?
    President:
  • 2,712 Answers
The only shelves you'll get for this model is probably the ones offered by the manufacturer.
The best way for longevity of the shelves, is to make sure that you do not put too many heavy things on it, and be careful when cleaning and replacing shelves..
Posted on May 28, 2008
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
Why is condensation in fridge?
Good afternoon friend, thank you for your post!
I understand that your Frigidaire refrigerator has moisture forming underneath the bottom panel of your freezer and that is causing water to drip onto your shelves. Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Jul 16, 2014 | Frigidaire Refrigerators
Can i remove the shelves in frigadaire frezzer model frs6r4eq4
Good Afternoon Friend,
I understand you want to know if you can remove the freezer shelves in your Frigidaire refrigerator, model# FRS6R4EQ4. All the shelving in your freezer is fixed, however the bottom shelf, which is located on top of the freezer basket, should flip up to allow more room for tall items that you wish to store in the freezer basket. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Refrigerators
Shelves are not the right size
Hello Mary Jo Lang - From doing a little research, and going on Frigidaire's site at the bottom of their page where it states "Recalls" it does not show that any shelves issue on refrigerators was affected on any recall list. However, in this particular case I would strongly suggest contacting the manufacturer directly for further assistance.
Jan 13, 2013 | Frigidaire FRT17G4B Top Freezer...
Have broken two bottom shelves in fridge door. Model no SRL551DP
Whats the serial number of the fridge. Its inside the fridge on the left on top of the sticker and also outside the left side of the freezer
Nov 08, 2010 | Samsung Refrigerators
I have severe ice forming in my freezer.
On this unit the shelves are the cooling coils and carry the refrigerant (freon) through the system. They will attract the warm moist air by design, so if you have an air leak in the door or elsewhere it will tend to build up there first.
This being said you need to check something else first. Make sure the other shelves are cold. If they are frosted and cold like normal then you most likely have a door that is not closing all the way or a bad seal. If the lower shelves are not cold then you have a system problem, typically a refrigerant (freon) leak that is causing the top shelf to absorb most of the work and not enough refrigerant to flow to the bottom shelves.
I hope this helps
May 06, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
Samsung Cooltech spare shelves available in b'lore??
it is possibly cheaper to go to a glass firm and get glass cut and edges polished to fit than it would be to buy replacement shelves.the mark up is horrendous on any spare parts......
Apr 20, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
Feb 09, 2010 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool ED5VHGXML10 Side by Side Door shelves cracked
HI thanks for your question. its the door liner, that's broken, if you can repair with some epoxy puddy, only problem with epoxy puddy , it smells. so the door liner is to be replaced. thanks the appliance doc. please rate my answer. thanks.
Oct 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
961 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
