Question about Microsoft Windows Server Standard 2003 for PC
Format i try to format c: but it showing that volume is in used by operating system
    Problem Solver:
  • 7 Answers
You Cannot Cut The Base (Branch) You Are Standing On.
Just Use Safe Mode With Command Prompt And From Command Prompt Try The Command "Format".
Although Some Basic Knowledge Is Required.
Booting With Dos Prompt May Be Useful
Posted on May 28, 2008
    Scholar:
  • 65 Answers
That is Becose your Windows sys dir is on in that drive mostlikely so you will need to format it from another os or from the installer of a os or mabey from a recovery CD
-Rel
My new Toshiba STORE ART 3 1 TB external Hard Disk is not working. i plugged it to my pc on windows 7. and it shows the drive in My Computer but when i opened it it saying that 'Please insert disk into...
Open your command prompt and format the drive type format volume [/fs:file-system]
volume: Specifies the mount point, volume name, or drive letter of the drive you want to format.
/fs:
file-system: Specifies the file system to use FAT, FAT32, or NTFS Floppy disks can use only the FAT file system.
Example.........FORMAT E: /FS:FAT32.....Press enter. E: is my second drive
May 19, 2011 | Computers & Internet
When i am connectind my portable hard drive with my laptop is showing only taksbar not showing in laptop harddisk pls send messeage
Try connecting it to another computer and if it also slows down, something is probably wrong with your external hard drive and you should get a new one.
Mar 01, 2011 | Maxell 665203 USB 2.0 Hard Drive
Hi Sir, I have a problem with my SD Card when im going to read it on my pc. It ask for "format the disk before you use it". When I click cancel, it says"your volume not contain...
Does the SD card have pictures on it? What is the camera model used with this card? Have you tried connecting the camera itself to the PC in order to transfer the card's contents?
Dec 17, 2010 | Computers & Internet
How to format my c drive help by dos
If you are running DOS(Command prompt) in Windows, your windows Operating System is installed in C drive and is Up and running then it is impossible to format the C drive because the whole thing is running in C drive and windows won't allow you to do so.
But if you are using a separate DOS O.S. and want to format C drive and If you want to format any other drive than c drive when your system is up and running then you can use the FORMAT command followed by the drive letter that you want to format.
here is an Examle to write in DOS..
Format C: /q
you can replace the C letter by any drive that you want to format. The /q Option is use to perform Quick Format. Here is a list of mostly used Option
Formats a disk for use with Windows.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/C] [/X]
"volume" Specifies the drive letter "/FS:filesystem" Specifies the type of the file system (FAT, FAT32, exFAT, NTFS, or UDF). "/V:label" Specifies the volume label. "/Q" Performs a quick format. "/C" volume will be compresse by default. "/X" Forces the volume to dismount first.
Hope this will help for sure.....cheers:)
Sep 28, 2010 | Computers & Internet
Cannot erase/format hard drive
You cannot format your c drive while running an operating system. You will need a bootable disk to complete this such as your operating system disk that your going to load.
Sep 03, 2009 | Western Digital HARDRIVES Hard Drive
Error loading operating system how can i fix it
Boot to your CD that you install from ... and try to FORMAT your disk without loading the operating system. If you can format successfully, with no errors, then you can try to reboot to your CD and then install your operating system again.
If the format fails, you probably need more help that I can give on here. Either your hard drive pooped out, or the partition is messed up, or something a little more serious than just an installation issue.
Once booted on to the CD, it will offer you several options - Do not reinstall Windows - you want to choose the Repair Option.
When the repair stuff has loaded (You may have to select which volume you wish to work on, if so just pick the number that is next to your C drive.) and you are at the prompt that looks like "C:>" you will want to type in the following, without the quotation marks.
"format c: /s"
This will take quite a while to complete and when it is done - IF it was successful you can try the install option upon the next reboot.
Jun 13, 2009 | Lenovo 3000 Y410 Notebook
I had to reinstall Windows Vista. When I did so my computer lost a significant amount of volume output from both the speakers and the headphones. I have tried increasing the decibel output on the mp3 files...
The format shouldn't have made a difference with the system volume? Try to Reboot PC, and when windows appear, hit F8 key constantly until you here a beep. You are now in the Repair/safe mode/system restore. This is where you need to perform the system restore. This should work..
May 17, 2009 | Microsoft Windows Vista Home Basic Edition
Partition Problem
Yuou must backup the data of d:\ in another harddrive or volume before doing this backup your data in another volume and then merge the data you can even copy the sectors from partion magic .Data can be recovered by using data recovery softwares.
Jan 20, 2009 | Microsoft Windows XP Professional
Format can not run @ c:
Its not possible to format the drive that the operating system is running from, that is C: so u need to unmount the drive and set it as slave so it would be drive D: then format it. that means the other drive would be the master running ur OS.
(it's like trying to cut a tree u are sitting on)
Mar 07, 2008 | Toshiba Tecra 8100 Notebook
Microsoft Windows Server Standard 2003 for PC Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
