Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Need wireing diagram for kohler 17 hp twin cylnder engine
  • 7,733 Answers
Try here -Link.
Posted on Oct 06, 2010
Wiring Diagram for a XT1 Enduro Series LT 46in 22HP V-Twin Kohler Hydrostatie Gas Front-Engine Riding Mower
To get a wiring diagram, contact the manufacturer/distributor directly.
May 19, 2017 | Garden
18 hp kohler engine starts but doesn't keep running!!!!
You put in a question about your ride on. What is it you need?
Aug 15, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
Question on craftman riding mower
with the ground wire off the coil and it turns over, you have a bad coil these engines are notorious for this. GOOD LUCK.....
May 23, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
How to reconnect kohler goveners
Without the numbers from the engine I can not get you the exact breakdown you need, this might help.
https://images.search.yahoo.com/search/images;_ylt=A0LEVy51DUpT0jUAMvlXNyoA;_ylu=X3oDMTB0Yjkwb3VoBHNlYwNzYwRjb2xvA2JmMQR2dGlkA1ZJUDM3MF8x?_adv_prop=image&fr=yfp-t-301-1-s&va=18+hp+kohler+engine+governor+diagram
If you give me the numbers including the spec number I will get you the breakdown you need.. Best of luck to you, please let me know if i can help..
Apr 12, 2014 | Garden
How much compression should a kohler 25 hp engine have
hi there
there are no published compression limits for kohler
the prefered method is to have the cylinders leak tested , because of the decompressor action built in while trying to compression test
but off the top of my head most machines would run best with a minimum of 100 psi or better
given that these have a compression ratio of 9:1
you could work it out
9:1 X 14.7 PSI ( 1 amtmosphere ) @ sea level = 131.00 psi
compression ratio = swept cylinder volume + clearance volume (@ tdc) divided by clearance volume
here is web site for obtaing service manual
http://www.kohlerplus.com/main_frame.asp
login as guest
select command pro twin -ch/cv 17-26
go to service manuals , select sm 24-690-07 file is 8.82 Mb and double click it and save a copy to your hard drive
cheers hope it helps
pauly46
May 07, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Electrical schematic
i need a diagram for the ignition switch on my craftsman mower
....7 prongs all labeled with letters sure what 3 are for not other 4
Apr 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need an owners manual for a craftsman 18 hp kohler mag twin 44 in deck model 917-257720. thank you
You can access the parts list and see the diagrams at Sears parts direct. I think its also printable. There will only be a part list for the tractor itself,not the engine.
YVW
mike
Oct 22, 2009 | Garden
Electrical wiring for kohler engine
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Jun 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
633 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
