Question about Toshiba Satellite A135-S4527 Notebook
Hi.. i am getting problem in my display in my laptop(toshiba brand). some time it works properly.Otherwise the green is prominent. Green color and hazyness comes during the boottime too. Plz suggest. Regards priya priyabrata.p@tcs.com
    President:
  • 2,712 Answers
It looks like a problem with the convergence IC's or one of the corresponding components. You will have to get the laptop serviced, I'm afraid..
Posted on May 28, 2008
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
Mar 31, 2016 | Toshiba Televison & Video
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
How to insert keyboard to cpu
Hi' keyboards even what kind of brands and models are usually of green color coding plugs , at the back of your PC you can see a female color green jack which is commonly for keyboards . Note; insert green plug properly on guide dowel connections .
Aug 11, 2011 | Computers & Internet
I have a laptop toshiba l500d series. My question is the screen turns green only the black parts all the time. What would be causing this problem. Thanks
Hi, the screen may turn green when the Graphic Driver is corrupted. Please re-install the Graphic Driver in the Computer. The Graphic Driver can be downloaded from the Laptop Manufacturer website. Restart the computer after installing the Graphic Driver. If the issue persists, restart the computer and try pressing F2 Key to enter BIOS (Basic Input Output System) setup, then check if the screen displays green color. If the screen displays green color in BIOS setup then the issue is related to Hardware of either display or graphic card of the Laptop. In this case, please contact the manufacturer of the Laptop to initiate the service under Warranty. If the laptop is not under Warranty then service charges may apply.
Apr 17, 2011 | Computers & Internet
Connected my laptop to Toshiba 27AF45 tv with VGA cable and RGB but it does not display properly - shows color and rolling black lines. Any suggestions?
Hello
VGA [Video Graphics Arrey] and RGB [Red-Green-Blue] sockets are not compactable, and will not get a proper display. You must have a converter [VGA=>RGB] is needed in between. Ok
Oct 19, 2010 | Toshiba 27AF45 27" TV
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
TV lacks green, but has prominant red/pink
Getting the squematic will be the first step to take to become more familiar with the electronics inside,you can ordered by going to http://www.servicemanuals.net/ click on service manuals and give them the model number,they will then give a price and availabilty.The color processing uses a driver for each color and an output for each color too,the output are ussually placed in the crt board in theneck of the tube.the drivers and outputs are transistors most of the time but sometime the drivers are part of an integrated circuit.Please let US know if you need more help but place it as a new question.
Oct 11, 2006 | Mitsubishi CS-35707 35" TV
Toshiba Satellite A135-S4527 Notebook Logo
29 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
