Question about iLO (2 GB) MP3 Player
Usb Whenever i try to put songs on my mp3 it says please remove write protection. How do i remove this?
Dear, sir
Hi
Thanks for your support, and unfortunately I still receive the same message the device (USB) have write protected. Any help please?
Posted on May 28, 2008
    President:
  • 2,712 Answers
After plugging your USB to the PC, go to Windows Explorer (right click START and select Explore).
In the left panel, scroll down until you see your device listed there. It will usually be the drive after the DVD/CDROM drive.
Click on the (+) to expand the folders. Find the folder that holds the Mp3 songs. In the left pane, right click on this folder and select 'properties'. In the General tab, at the bottom, you should see Attributes. Make sure "Read Only" attribute is unchecked.
Try to copy paste Mp3's into this folder now. It should work.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Write-Protection?
Put them into "my sounds" folder or into a music folder and use them from there. The ring tones are wright-protected.
Jun 22, 2010 | PNY 2GB microSD Memory Card
"Bad Track" Messages on e260
You have songs that may be protected or the wrong format for your device.
delete the bad song and download another copy from a different source and try it.
This is not to uncommon due to different file formats and protection in the song files
When you rip songs from another device often some won't load or play in another device
especially if they are paid for songs.
May 12, 2009 | SanDisk Sansa e260 MP3 Player
NokiA 5310
Hi
Most probably it is because of the music file format check the entire steps out
  • If u use a usb cable
  • Check pc suite is installed on your computer or not
  • U can drag and drop the songs to the Music folder.
  • The nokia browser will appear in your window explorer
  • U can view your phone folders like using the window explorer.
Also check the music file format
The Nokia 5310 plays MP3, WMA (windows format), AAC and M4A (also known as eAAC+), but only the non-protected files.
There is one way to convert your protected songs, which is to burn them to an audio CD (which is usually a "permitted" action for protected songs), and then rip them back to MP3 or so.
And please do rate me
Feb 10, 2009 | Nokia 5310 Cellular Phone
I cant put songs on my sansa
it is look like it is psword protected ,or has some kind the buton wich does not let you put/remove song's fom it.try to find that buton or rest to factory seting, format the player.
Jan 14, 2009 | SanDisk Sansa m250 MP3 Player
How to remove write protect on my usb flash drive
Make sure the hold button isn't on. It's as simple as that.
Sep 09, 2008 | SanDisk Sansa Clip MP3 Player
My brother just bought an mp3 player and it wontt let you put songs on it. Whenever wetry, the littlered triangle comes p and tells us tha there was trouble downloading the song onto the mp3. WEe've tried...
On some mp3 players, the songs cannot be copy-protected, even if the specs say they can take wma format. Also, the cheaper music subs don't give you transfer rights, even though they allow you to play the song on your computer. What music svc are you using? It makes a big difference.
Jun 25, 2008 | Audio Players & Recorders
How do you remove song from your mp3 4gb sansa sandisk
1. Either your MP3 playr is write protected .
2. there is some problem in firmware .. lode firmware thru cd ..
Jan 15, 2008 | SanDisk Sansa e260 MP3 Player
Coby mp3 player problem
Write the songs to a CD (or a CDRW) first, then re-rip them to Windows Media Player/iTunes/whatever as mp3s, or unprotected WMAs.
Honestly it's easier to burn and re-rip than remove the copy protection. When you burn it to a CD, the DRM goes away, and you'll have a new file that actually plays on your player.
Dec 23, 2007 | Coby MP-C883 MP3 Player
Sansa shaker files write-protected
SHAKER ONLY TAKES MP3 FORMAT!!!!!
Use this site to change your format to the correct one for the sansa shaker. This is the only way to load songs from your cds MWA will not work at all. Must convert all files to MWA use site below
http://www.wma-mp3.org/
Dec 10, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
iLO (2 GB) MP3 Player Logo
37 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
