Question about Ovens
Kenmore Classic Wall Oven Model # C97047191-2 Serial # NF91008197 nothing on it works (was fine last night) checked the 3 fuses under the stove and the breaker is good on the electrical panel. Is there any kind of reset button or other fuses that would keep the oven from working? It looks like there is no power going to the stove.
I think that the ONLY problem is to set properly the TIMER; The TIMER is set OFF and the OVEN does not work; try to push and/or release the timer buttons and it will work. I have the same problem and it is very unfortunate that I have no manuals.....
Posted on Feb 07, 2011
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
Oven went last night after tripping fuse when flipped back on stovetop works but oven doesn't how do i fix this issue
there are often fuses on the oven somewhere.if u can type your stove model into google and get schematics for your stove it should show u where they are on your stove. hope this helps
Nov 11, 2010 | Ovens
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
My question concerns a Kenmore glasstop electric oven (model #790.95200100). While operating the oven at 450 degrees and the back right burner at level 5, I heard an audible "pop" and saw a flash of light...
After letting the stove cool, I pulled the entire unit out from the wall and discovered scorch marks on the wall. Opening the back panel revealed a simple fix: the "element on" light module had shorted and was visibly scorched and melted. Looks like a simple replacement (and some wire stripping where the leads fused). Stove currently works with the affected wires capped off (while I await a replacement module).
Sep 14, 2009 | Kenmore Ovens
Oven not working
you would have to check the element for continuity. Also the oven sensor could be suspect and should ohm out at 1180 at room temp. if both those are ok then main control is probable. without schematic it would be hard to say for sure..there may even be a safety fuse blown.
Jun 13, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Convection STove - All Oven elements non-fonctional
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Glass top Convection self cleaning stove
I find the front door isn't shut tight enough and I prop a dowel up against one corner and the other end to the floor and then it works.
Oct 23, 2007 | Ovens
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
292 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
