Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
Set-up - WinTv HVR 950
Dear Sirs,
I purchased this product about 1 year ago at best buy here in Myrtle Beach, SC 29577. I was never succesfull in getting in fully hooked up
although I did manage to record a couple television items but had a
flash sign saying I needed to have a de-coder for that. What I need are
EXPLICIT instructions beginning with how the cable is hooked up from the wall to the TV to the PC.Any information is appreciated and I can copy
it for my future use.I use dial-up and plug into a 2.0 connect in the
front of the pavillion. My goal is to copy some news briefs as well as
other items of interest to me. Can you help me? Am most grateful
for any assistance you might gige me in this matter.
Sincerely,
Reik A. Wilson E-mail ReikAWil@AOL.Com
  • 19,396 Answers
Here is the user manual:
WinTV-HVR-950
Posted on May 28, 2008
  • 2 more comments
  • Ginko
    Ginko May 28, 2008
    If you want to use WinTV-HVR-950 to watch and record analog cable TV
    with Microsoft's Media Center application under Windows XP or Windows
    Vista, do the following:
    • Download the Hauppauge Media Center software video recorder: MCE_software_encoder
    • Run the file. This will install the Hauppauge SoftMCE MPEG-2 recorder for use with Media Center
    • Reboot your PC.
    Now, when you run Media Center, go to Tasks / Settings / TV / Set Up TV signal
    At 'Set Up your TV signal', click Next
    At "Regional settings', make sure your region is correct and click Next
    At 'Download TV options', click Next.
    At "TV Signal', click 'I will configure my TV signal manually' and click Next
    You will then see: Cable / Satellite / Antenna. Chose the source of your TV signal (Cable for use with analog cable TV) and click Next.
    Click through the rest of the settings, set up your Guide listings and click Finish. Then return to the main menu.
    Go to TV + Movies and then live TV to watch and record TV.
  • Ginko
    Ginko May 28, 2008
    For device setup and cable hooking refer to WinTV-HVR-950 guide. It presents a simple explanation of installing procedure. The only cable you have to connect is the round shaped connector aerial cable. it must go from your tv card to the aerial, either a portable one or the one on the wall.
    I think in your case you should solve the problem by installing the required software encoder, as explained above.
    Regards
  • Ginko
    Ginko May 28, 2008
  • Ginko
    Ginko May 29, 2008
    Let me know if the post solved your problem or you need further help,
    Thanks
    Scholar:
  • 198 Answers
Helo sir / madam,
i understood the problem.... but can you give much more technical details bout ur product... thank u
I have wintv-hvr-1950 hauppage box which suddenly stopped showing light. all things are connected as always - computer/internet working fine -Windows 7 - WinTVV7 screen opens black on my monitor
Make sure the power supply is working. Quite often you get a pretty crappy power supply with USB devices, so that is what I would suspect. Its a 5 Volt supply, and should get a little warm if its working. I don\'t think this device will work without a power supply.
Those supplies are quite standard, so bring your old one to Fry\'s, MicroCenter, Radio Shack, Best Buy, or even Walmart or the other stores to compare Volts, Amps, and polarity/size of the plug to make sure you get one that will work.
Sep 26, 2014 | Hauppauge Hauppage WinTV-HVR-1950 USB TV...
I have specs player I'm. In myrtle beach. Sc I
Probably just need to reset the cameras so they obtain an IP Adress that is valid on the SC network.
Jul 02, 2014 | NetGear Computers & Internet
Tv tuner
Basically what I can see from what I have read one had dual tuner capability and one is set up for PCI Express. Both look like great cards.
http://www.hauppauge.com/site/products/data_hvr1600.html
http://www.hauppauge.com/site/products/data_hvr1800.html
Thanks
Armymason
Feb 24, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Oct 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Problem installing WinTV HVR 1600
It just means that it is not not registered to work with windows by microsoft.
The manufacturer doesnt have to work with Microsoft to make their products work.
If possible you can go ahead with the installation. To be safe set a restore point before doing so, though
Jan 12, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Open Questions:
See all Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / Questions
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
159 people viewed this question
Top Hauppauge Televison & Video Experts
Iqbal Husain
Iqbal Husain
Michael Galve
Michael Galve
jason
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
