Question about Star Logic Monitor
My 19" monitor use to power down automatically when not in use. It stays on all the time now. I have set the power setting on my computer to power down the monitor after 15 minutes but it still does not do it. I do not want my computer to go into sleep mode to have this happen
  • 1 more comment
  • dka3280 Oct 06, 2010
    I want my Star Logic 19" monitor to Automatically power down,(Model #MJ9BBK) like it used to.
    I have tried using the power settings on the computer and they do not work in powering down the MONITOR. I do not want my computer to go into sleep mode. I have the power settings as stated:Turn computer off NEVER and turn off the display AFTER 15 MINUTES
    Thank You I will give this a try
    Yes it was, it answered a question I wasn't sure about
    Genius:
  • 1,035 Answers
Hi. This is not a monitor problem. Your computer will just command the monitor to go off under the power management. Since it is not doing that. There could be a problem with your windows operating system. Have you tried using other computer and do the same power settings and see if it doing the same. Some computer have power management software. Check your computer manufacturer's website if they have software upgrade for the power management.
All the best!
Posted on Oct 06, 2010
  • 857 Answers
Follow these steps :
Windows XP :
1.
Go to Start then Control Panel and click on Power Options.
2.
On the Power Schemes tab, select Home/Office Desk in the Power Schemes drop-down box.
3.
In the box labeled System standby, select Never
4.
Click OK to save your changes.
Windows Vista :
1.
Go to start and type in the search box Power Options hit the enter button.
2.
On the Left side there is a panel Click Change when the computer sleeps
3.
Click the drop-down box which says Put the computer to sleep and select Never
4.
Click Save changes
  • Jayant Jha Oct 06, 2010
    Ok it seems to be a problem with the operating system itself. This may also happen because of Excess heating of CPU.
    What you can try is, backu your data and then take your computer back to factorey settings or reinstall the operating system and see if it helps.
  • Jayant Jha Oct 07, 2010
    THIS should help !!
I JUST PURCHASED A NEW 19INH AOC MONITOR TO USE WITH MY E-MACHINE. IT WORKS FINE EXCEPT IT SHUTS DOWN WHEN I LEAVE THE COMPUTER AND STAYS THAT WAY UNTIL I MANUALLY START IT AGAIN.
Hello Eldon, don't worry this is a safety devise that is built in to your unit and many others. It gives your screen longer life. GOOD LUCK.
Oct 22, 2011 | AOC 931SWL 19 inch Monitor
How do I set the NEC LCD194WXM monitor to shut down after 5 mins, 10 mins, 1 hr., etc., etc. Mine stays on all the time!
To change this, do the following:
1) Navigate to the Control Panel by clicking Start and then Control Panel. Then double click on Power Options as shown below circled in red.
2) This will then display the Power Options window as shown below.
3) Once you have opened the Power Option Properties, under Power Schemes select the one that best suits your PC system.
4) Then you can select whether or not to switch off your monitor and/or hard drives after a period of time when it is not being used.
Apr 15, 2011 | NEC MultiSync 1940CX 19" LCD Monitor
My monitor wont stay on.
Navigate to the control panel and double click power options. On the Power Schemes Tab ensure that all the fields are set to NEVER.
This will keep your monitor on all the time.
Thumbs up!
damnor01
Feb 01, 2011 | Gateway FPD1975 19" LCD Monitor
Monitor goes on and off........seemed to come on for the xp boot, but then disappears or is intermittant when the xp login page appears. Only fix sometimes is to reboot the computer. Very strange. Only...
In your Windows XP
  1. Go to Start and click
  2. The Start menu will open
  3. In the start menu click settings
  4. In the settings select "Control Panel"
  5. The Window of control Panel click "Power Options"
  6. In the Power options you will find Display time settings. These are the time settings that determine the time like if your computer stay idle for 5 min, the display will shut down.
  7. I suspect that this time is set to be very low like if there is no activity on the computer such as key punching, typically happens when you are reading an e-book Windows will automatically shut down the display. So you can increase the idle time to say 7-10 minutes and/or a similar setting is "Put the computer to sleep". Try to carefully alter the time values and you will find a good settings that work for you.
If the above tip does not work then there is definitely something wrong with your monitor's hardware most probably the power supply. You need to check it with a repair shop.
Good Luck!
Dec 09, 2010 | Xerox XG-71D 17" Flat Panel LCD Monitor
How to prevent my computer to shut down automatically?
Control panel, power settings, set the times you desire in there and you can have it stay on longer or shorter, shut the monitor and drive or just shut the whole thin is as many minuter or hours a s you like, The longer it stays on, of course the shorter the battery life
May 21, 2010 | Acer Computers & Internet
How do I set the monitor so the menu will stay on long enough to change it?
There should be a setting in the monitor menu listed as OSD (On Screen Display). Try increase the length of time for it to stay on longer.
Nov 09, 2009 | X2Gen MG19MY 19" LCD Monitor
DOES NOT GO TO STANDBYE STAYS ON ALL THE TIME
Go to the power options under the control panel and set it to standby/sleep after a set amount of time.
Jun 28, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
My ViewSonic monitor just blacks out for no reason
It could be a setting you could have done on the "Power Saving" settings under "Screen Saver" settings, if you have Windows XP. Like "Turn off monitor after" a certain time. Even if you don't have Windows, please check the Power Save settings.
Jan 29, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
Dell E196FP TCo99 Monitor screen problems
The screen colour changing is apparently an auto test procedure on the monitor and was prompted by a fault with the monitor not automatically shutting down when the computer is shut down. The settings on the monitor have been adjusted to rectify this and the problem is now gone.
Apr 06, 2008 | Dell E196FP 19" LCD Monitor
Monitor black out
try to adjust the setting of your video and refresh rate
Mar 12, 2008 | Videoseven V7 R19WPS 19" LCD Monitor
Star Logic  Monitor Logo
125 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
ray gallant
jd83854
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
