Question about Casio CFX-9850G Plus Calculator
I had entered an equation into graph mode. I went to the range and tried to change it, I did, and the graph was spread out way too far. I tried to go back into the same place to re-enter the old range, and I did, but now it is saying range error and I can't get past the Y1=, Y2=, etc page. Help?
  • Casio Master
  • 7,993 Answers
You can reset the calculator. There is a button on the back.
You can also Press ZOOM and select standard STD or auto.
If you want to enter windows dimensions manually, make sure Xmin is less than Xmax, and Ymin is less than Ymax.
Posted on Oct 10, 2010
How do I graph a simple equation, without getting an error 07 message? y=-1.5x+3
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
Jun 11, 2014 | Texas Instruments TI-86 Calculator
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax
y= (-) 1.5*x +3
c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
Cannot graph two equations together, & trig graphs are not correct.
At first in Y editor type Y1=2*cosx and for example y2=[5*exp(-x)]-5 and then graphing it. Set RAD mode of course. See captured images
Jul 10, 2012 | Texas Instruments TI-84 Plus Silver...
Today i was trying to graph y=2x+23, but when ever i would press graph it would pop up window variables domain. What do i do to fix this?
Your ranges for your window settings are more, or less out of bounds with the equation y=2x+23, that you entered.
Press the [green diamond], and the [F2] keys to bring up the graphing coordinates. Enter the following values to fix the graphing coordinates. Starting at the top, xmin= -8, xmax= 8, xscl=1, ymin=0, ymax=40, yscl=1, xres=2. Now, press the [green diamond], and the [F3] keys, and the graph should display.
Dec 18, 2010 | Texas Instruments TI-89 Calculator
I have a student in my Precalculus class who is trying to graph several equations simultaneously, and her calculator will only display the graph of one equation at a time. In the equation editor, the...
Some time or other she played with the Transfrm Application. It remains in memory and takes over the graphing capabilities of the native OS. It must be kicked out of memory.
  1. Press [APPS]
  2. Use Up or Down arrows (Up is faster) to get to the bottom of the APPS list.
  3. Locate [:Transfrm], highlight it and press [ENTER]
  4. In subsequent screen, select the [UNINSTALL] option.
  5. Go back to the [Y=] screen and enter or edit your functions.
  6. Press [GRAPH] when finished entering the functions.
Oct 07, 2010 | Texas Instruments TI-84 Plus Calculator
My graph is not showing up when im typing an equation....the line will show and the points but not the graph....plzzz help!
Your graphic is drawn in dotted style. Change it to connected if you want.
Press [MODE] Use arrow to highlight Connected and press [ENTER]. Press [GRAPH] tor edraw your graph.
Hope it helps
Oct 27, 2009 | Texas Instruments TI-83 Plus Calculator
I can't graph more than one equation in the y= area of my Ti 84+
The marking that so puzzle you define the type of line (or dots) to represent the graphs. Enter as many functions as there are Y variables.
After entering a function press [ENTER] to jump to the next one.
When finished entering all functions press GRAPH. If you want graphs drawn one after the other, in MODE highlight Sequential (6th line) and press ENTER. If you want graphs drawn simultaneously, in MODE (6th line) highlight Simul and press ENTER. Press 2ND QUIT to return to previous screen . Execute graph again.
Hope itr helps.
Sep 23, 2009 | Texas Instruments TI-83 Plus Silver...
Ti 84 plus problem
The calculator only displays from -10 to 10 on the x and y axes, and both of your lines are outside of that range. However, it is easy to change that.
1. Hit the gray "WINDOW" button that is directly under the screen
2. Change "Xmax" to 150
3. Change "Ymax" to 200
Remember to change both of those values back to 10 when you are done with this problem!
Here's how to graph it:
1. Hit the "Y=" button
2. Enter your first equation after Y1, and your second equation after Y2
3. Look over both the equations to make sure you typed them correctly
4. Hit the "GRAPH" button
5. If you don't see the intersection you will need to adjust Xmax and Ymax again
6. Hit Hit "2ND" and the "TRACE" to bring up the "CALC" menu
7. Scroll down to "intersect" and hit enter
8. Hit enter 3 times (You use the first and second curve options when you have more than 2 lines)
9. It should display the coordinates at the bottom
10. I got (76, 142.1) for the intersection
Thanks for asking this question! I used to do this a much harder way, but while I was calculating the answer to your question I hit a wrong button and accidentally found this method!
Jun 30, 2009 | Texas Instruments TI-84 Plus Calculator
How to graph linear equation in two variables
I am not quite sure what you are asking...
(1) if asking for graphing y= -2/3x+2, then press [diamond] [F1: Y=] type in .2/3x +2, see graph by [diamond][graph]
(2) if asking for graphing y= -2/3x+a, where a=3x, then first archive a=3x in Home screen by [home], type 3x [sto] a, then go back to y= menu, and type -2/3x+a in Y1
(3) if asking for graphing an equation that is dependent on 2 variables at the same time, use x-y-z axis (aka, change mode to graphing 3-D by [mode]graph [5:3D]) then enter desired equation in y= menu using Z function in terms of x and y aka z(x,y)= ...)
May 18, 2008 | Texas Instruments TI-89 Calculator
Graphing
The first solution will allow you to watch your calculator graph two equations simultaneously rather than finishing one before graphing the next; it won't solve the problem of having the calculator unselect one equation when you select a second. To fix that problem, try the following:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site
- doug garfinkel, Children's Day School
Jan 15, 2008 | Texas Instruments TI-84 Plus Silver...
Casio CFX-9850G Plus Calculator Logo
53 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
