Question about Brother MFC-8440 All-In-One Laser Printer
Image in scan black only - Brother MFC-8440 All-In-One Laser Printer
EPSON XP400 SCANNED IMAGE FADED B&W OR COLOR
try to reinstall drivers or try to scan connected to other pc, if problem remains, scanner is done
Feb 02, 2015 | Epson Office Equipment & Supplies
What can I do about black spots on scanned images?
Have you cleaned the scanner glass bed lately?
Apr 26, 2017 | Office Equipment & Supplies
Color image scan produces black and white pdf
This is purely down to the scanner settings. In the scan settings, choose the resolution and if to scan in monochrome (or B&W) or colour. SAVE the settings. Try a rescan and you should find that will work.
Nov 26, 2013 | HP Officejet Pro 8600
Scanner operates but only black scan appears
I have many years experience repairing Canon scanners so here is my suggestion for you.
If you try to scan in another peice of software is the image still black? Try using Microsoft paint to scan a document or picture in with. If you get a good image then the software your using to scan with needs to be corrected its probably a setting in the software.
If you scan with another piece of software like microsoft paint and the image is still black then my guess is that your imaging lens is defective on your scanner and will need to be replaced. If that is the case its probably cheaper to buy a new scanner then to have it replaced.
I hope this helps you out.
Feb 20, 2011 | Canon CanoScan 3000F Flatbed Scanner
My scanner scans black Does not scan document.
Does the scanning light come on? The light may be burned out. Also Try cleaning the scanning tip.
Jul 17, 2010 | Visioneer RoadWarrior Patriot Handheld...
Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Jan 13, 2010 | HP Photosmart C7280 Printer
The scan comes out as a solid black image both in the preview and in the actual scan.
This is a preview from a related model, you must set the profile to photo and the color format of your reference. Hope this helps.
Nov 18, 2009 | Brother MFC 4800 All-In-One Laser Printer
Faulty scanned images
Pls check your color Scan settings. Generally there will be some color difference between the original and scanned Image because, the original is 'reflected light' whereas, the scanned image is a 'source light' on the monitor. The monitor setting can also affect the color output. S. Mohan
Jan 28, 2009 | HP ScanJet 2400 Flatbed Scanner
Scanned image only prints in black and white
it's tricky / annoying:
you have a preview ...
you have some of the (3) images checked
but also you have some of these images selected (blue outline)
now:
when you select (I don't mean the checking) an image you'll have to set the scanning params
again - or check them ...
if you select an image, and then set the params (like "color"), your scanned image will be in color
also resolution is the same way ..
especially after crating preview .. it'll be set to 300 Dpi
so after seecting one for scanning - check the resolution too :)
jepe
Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
Brother MFC-8440 All-In-One Laser Printer Logo
23 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
