Question about Fisher and Paykel GWL11 Top Load Washer
The wash machine started leaking water from bottom and then a few loads later it started smoking with a electrical burning smell and automatically shut off. The number is GWL11US
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now a couple of things could be the cause.If the pump was leaking and went open circuit this would explain why your machine will not power up because the pump is part of the power circuit for the control module.Try this,look under the machine to the front right and you will see a fan.This is your pump.Look closely at it with a torch and see if it is corroded or burnt.Also look for any evidence of leaking and burning.Please reply back on what you find and then I can guide you in rectifying this fault.Looking forward to your reply.
Posted on Oct 06, 2010
My calypsal washer smells like burning electrica or rubber in the spi mode
The motor could be leaking oil. Pull the machine out and look for stains or puddles on the floor.
Oct 07, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag Neptune frontloader washer smoking last few minutes of spin cycle
I need more information can you tell me if the smoke smells like rubber burning or if it smells like electricity burning like the wires burning?
Oct 01, 2012 | Washing Machines
My washer keep shorting out why is this
It may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell.
If the washing machine is old (15 - 20 years) you could have nuisance tripping on aGFCI outlet, however that doesn't mean you get rid of the protection of the outlet, it means you probably should consider replacing the washing machine for a newer model.
Apr 30, 2011 | Washing Machines
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Smell like burning rubber
if it smell's like rubber it likley is .. smell's like a belt driven and it needs a replacment belt & idler .. remove the two screws at the bottom of front panel an remove .. in the front center at the bottom .is the motor / belt and pump .. if there is black rubber in bottom / wala . the belt is burning . / look for pump leakage / this would get belt wet and slip.. thanks mm .
Dec 02, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Smoke
Your complaint is a bit vague but since it had only been in the cycle for 1 min., it should have been too soon to have enough water to start washing, so it's possible that the fill valve may have shorted out. Unplug the washer and inspect the area where your hot and cold fill hoses connect to the washer. Turn the water off and remove the hoses. If you can gain access to the part that the hoses were connected to, you should be able to visualize where the burning came from. It is possible a small water leak may have dripped onto the coils of the valve and caused it to short out, so that will need to be fixed also.
Hopefully, This is what your problem is.
May 27, 2008 | Amana NAV8800E Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
95 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
