Question about Protron PD-800 DVD Player
TURN OFF PROGRESSIVE SCAN PD 800
I have a Protron PD 800 DVD and must turn off progressive scan because no image comes from TV and my TV doesn't suppport PS. How can I do if I can't see the menu on screen? I have no manual
    Genius:
  • Protron Master
  • 1,550 Answers
Try with this,with the disc tray empty turn on the dvd then push for 5 seconds the button stop.If this don't work connect to the tv on the video signal the y connector you got signal on black in white but you can see the menu to deactivate this function.Good luck.
Posted on May 28, 2008
When i try using prgressive scan it comes up error why and how can i get progressive scan to work
In order to use progressive scan you must have a progressive scan compatible tv. Check your users manual to find out if its compatible. If it is it should give instructions to turn on the progressive scan option for tv.
Aug 26, 2011 | Zenith XBV442 DVD Player/VCR
How to reset (manually) factory defaults?
Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps
Sincerely,
Michael Scott
Nov 16, 2008 | Protron PD-DVR100 DVD Recorder
DVD player stuck on progressive scan
Try unplugging the power cord from the wall for at least 24 hours. This should cause the unit to 'forget' the setting for progressive scan, and return to the default interlaced. If this doesn't work, you will need to find a remote to get into the menus to reset this option. Perhaps a universal remote will work? Let us know if this works!
Oct 06, 2008 | Protron PD-800 DVD Player
Progressive scan
Without disc on the tray turn on the dvd then push the stop button for 5 seconds.Good luck.
May 27, 2008 | Protron PD-800 DVD Player
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
PSCAN shows up on my tv screen when I try to watch movies. How do I delete this?
The solution to the PSCAN! (half screen cut image) is just as suggested, turn off the progressive scan switch in the back of the DVD player to get the full image and enjoy your movie.
Dec 26, 2007 | Memorex MVD2040 DVD Player
Picture problems
Scrolling/black-and-white/"out of tracking" display on a DVD player is generally caused by the DVD player being switched into Progressive Scan mode on a TV not capable of viewing that content. Scan the remote for a button labeled Progressive, I/P, P.Scan, or anything similar. Scan the user manual for information on resetting this also. If the manual and remote come up dry, call Protron and see if there's a key combo you can hold to reset that. Often, holding Play for 5-10 seconds will reset to standard (Interlaced) mode, or holding Stop while turning the unit on. Sometimes, holding Display on the remote for a few seconds will also switch this setting. Good luck.
Jul 11, 2006 | Protron PD-800 DVD Player
Protron PD-800 DVD Player Logo
204 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
