Question about HP Office Equipment & Supplies
My HP 5 MP printer says memory not sufficient when there is a word document of say 10 or 20 pages without tables,graphs, or pictures. What to do? It has 3 MB memory.Is it enough or not? The message on a page I get when it does not print the entire document is as follows: the job require more memory than is available in this printer. try one of these: for the output format, choose Optimize for Portability. Where do I fix this? In the Device seting page, make sure teh Available PostScript Memory is accurate. How to find what is the accurate amount of memory? and where to find it? Reduce the number of fonts in the documnet. How can this be done? Print the document in parts? How this can be done? Thank you an advance for your good help.
  • HP Master
  • 7,733 Answers
Try HPS ----->LINK.
Posted on Oct 05, 2010
I send a print from Word. The green light that normally blinks goes on solid and no printing happens. I push the long reset button and 1 page comes out with one line of gibberish across the top. The...
Does it happen from every word-document? This is a postscript error. It can be in your document (you can test it by making an other document in word and print it. If it comes out properly, than you have to look for components like photo's, pictures, graphs in your document that causes the problem. It can also be a problem of your driver. In that case you need to uninstall and re-install your printer again. It can also be a memory problem of your printer. Please turn off your printer, wait a while, than turn it on again and see if it is still the same problem.
Aug 05, 2011 | HP LaserJet 6p Printer
I have an HP Color Laserjet 4600. I am printing a large 46 page document with many graphics and photos. Randomly, a page will print without half of the picture or with words left completely off. I have...
In the printer driver's properties page, disable the bidirectional support.
Start => Control Panel => Printers =>
right click on your printer =>
Properties, under the 'Details' tab click "Spool Settings" and down the bottom you can choose not to support bidirectional support
Your step bt step may not be exactly that depending on your OS. For instance, in Windows 7, this setting is under the PORTS tab
Since you didn't specify what OS you are running, that's the best I can do for the moment.
Mar 10, 2011 | Office Equipment & Supplies
How do I scan a picture from my HP (Printer*Scanner*Copier on to my PC
To scan a picture follow the following steps :
1. Click on start then click on All program
2. Click on the HP , and then click on HP Solution Center 3. If you want to scan a photo then Click the on-screen Scan Picture "button" in HP Solution Center.
If you want to scan a document without document then Click the on-screen Scan Document "button" in HP Solution Center.
4. Set the option to prompt for settings each time you scan, and then click OK
5. At last click on Scan.
and save your file.
Regards
Ashly
Feb 25, 2010 | HP Photosmart C4180 All-In-One InkJet...
Printing multiple test pages
Check for a sticking button on the printer itself. The big Green button will produce a test print if pushed. Also try disconnecting it from the wall outlet overnight to reset it.
Jul 27, 2017 | HP LaserJet 1320 Printer
I have an HP Color LaserJet 3800 printer. I am trying to print a document and it keeps printing: PCL XL error Subsystem: GEDI Error: MemA L LocError Operator: ReadImage Position: 743
That means that the printer does not have sufficient memory tp [rint the document, if it is a text document (eg word) try to print pages in groups, if it is a different document try the following:
" I receive a 'PCL XL error' on my HP 4100mfp when making a 2 page copy as one page in duplex? Why?
The problem is related to a printer memory problem.
If following parameters are set in the HP 4100mfp you will receive and 'Insufficient Memory" error.
1) In 'COPYING' the 'IMAGE QUALITY' is set to 'BEST'
2) In 'ORIGINALS' the 'CONTENT' is set to 'PHOTO'
Following error message is printed:
PCL XL error
Subsystem: GEDI
Error: InsufficientMemory
Operator: EndSession
Position: 32
The solution is to set 'CONTENT' to 'MIXED' or 'TEXT' or set 'IMAGE QUALITY' to 'NORMAL' or you can add additional memory to the HP 4100mfp. "
from euroform.com - FAQ
Dec 22, 2008 | Office Equipment & Supplies
Hp laser jet 1010
Dr.M.subrahmanyam
1. This printer is not specifically a postript printer. It uses HP PCL printer control language, according to HP it does not support Postcript, see the table on page 15 of this pdf file: http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00442162/c00442162.pdf page
2 Screen prints are not directly sent to the printer. They are copied to the Clipboard - you must open up another application which can access graphics - WordPad , Word, Excel. E.G from wordpage paste the screen print (using Control + V or Edit-> Paste) and the contents of the clip board will appear in the document - use the print option from wordpad to print this graph to your HP 1010 printer.
Feb 21, 2008 | HP LaserJet 1010 Printer
220 people viewed this question
Seeker5211
Seeker5211
