Question about Samsung Refrigerator Water Filter DA2900003G DA2900003B
My old filter DA29-00003B-2 was replaced with the new model DA20-00003G which doesn't fit when I am trying to install it. The top of the nozzle has smaller size hole than the old model. All samsung websites advise that both models should fit. I called many places, including samsung but no one actually wants to help
  • kboyd771 Feb 28, 2014
    I have the same issue. My Samsung frig takes DA29-00003G. I've bought two recently and neither will fit. I called Samsung, but they would not help me.
5 Suggested Answers
  • 111 Answers
SOURCE: Water Filter light still red after new filter installed
You have to reset the light by pressing and holding the touch pad for 3-5 seconds. It doesn't reset on its own when you replace the filter
Posted on Dec 19, 2008
bobicehouse
  • 1524 Answers
SOURCE: Hi Does anyone know where I can find a rs21dcns
http://downloadcenter.samsung.com/content/UM/200605/20060509094228828_DA68-01365A-1.0.PDF
Posted on May 05, 2011
  • 1116 Answers
SOURCE: replaced DA29-00003B water filter in
Recheck you steps and see the warnings:
1) Turn on the main water supply & shut-off valve of the water
supply line.
2) Run water through the dispenser until the water runs clear
(6~7 minutes). This will clean the water supply system and
clear air from the lines.
3) Additional flushing may be required in some households.
4) Open the refrigerator door and check if water leaks around
the water filter.
Remove any residual matter inside the water supply line after installing filter.
NOTE :A newly-installed water filter cartridge may cause water to briefly
spurt from the dispenser.
Posted on Jun 04, 2011
  • 3 Answers
SOURCE: I have a Samsung fridge
make sure that the new filter is lined up properly and exert a little force then turn until it clicks
Posted on Jun 09, 2012
Best way to take it off
Acura Coupes and Sedans 1986-1993 Repair Guide
Fuel Filter
Print
The recommended change interval for the fuel filter on all models is 60,000 miles under normal service. Severe service will require more frequent changing of the fuel filter.
The filter is located in the passengers side of the engine compartment.
CAUTION Before disconnecting any fuel lines, be sure to open the gas tank filler cap to relieve any pressure in the system and wrap a shop towel around the fuel line fitting before opening. Observe all fuel handling precautions.
REMOVAL & INSTALLATION
See Figures 1, 2 and 3
  1. Disconnect the negative battery cable.
  2. Wrap a shop towel around the fittings and using a proper wrench, slowly loosen the fuel line fittings.
  3. Remove the 2 banjo bolts from the fuel lines.
  4. Remove the fuel filter clamp retaining bolt and the clamp.
  5. Remove the filter from the vehicle.
It is very important that ALL of the fuel line banjo bolt washers be replaced every time the banjo bolts are loosened. If the washers are not replaced the fuel lines will leak pressurized fuel causing the risk of fire or explosion.
  1. Install the new filter in position and tighten the clamp mounting bolt to 7 ft. lbs. (10 Nm).
  2. Attach the banjo fittings with new washers in place. On Legend and Vigor, tighten the fuel line flare connector to 28 ft. lbs. (38 Nm). On the remaining models, tighten the banjo fitting bolts to 20 ft. lbs. (27 Nm).
  3. Start the vehicle and check for leaks.
Fig. Fig. 1: Disconnecting the fuel lines from the fuel filter
Fig. Fig. 2: Fuel filter replacement-1991-93 Integra
Fig. Fig. 3: Fuel filter replacement-Legend and Vigor
Jul 08, 2012 | 1991 Acura Legend
Tried to replace the heating element on a kenmore fridge but new model dual defrost heater doesn't fit. How can this be if the new model is now replacing the old single bracket?
Is the part# WB51X 442 or WB51X443 ?
If it is, thats the replacment for the single one that GE made refrig. for Sears,GE had such a super high failure rate on the single they are replacing them with the dual heater and it will fit as long it isnt to long the WB51X442 was for narrow freezer and WB51X443 is for larger cubic feet refrigerators.
Gene
Aug 09, 2011 | Kenmore Side by Side Refrigerator
After replacing the cartridges, it doesn't print. Is there a problem with the head as the printer was not used for a long while
After installing new catridges, try to goto the printer options. in the serives option do the ALIGN THE CATRIDGES. then it will aligh the catridges correctly and it may print.
This procedure works for some models of printers.
Jun 14, 2011 | Office Equipment & Supplies
Installed new pro series sand filter model s244t. same size filter as we had before. bottom drain has been plugged and not in use. can prime pump basket and backwash with limited flow. same thing when...
check impeller may be worn might need replacing scuffing markers change orings too maybe bad seal on pump too push seal out with fingers try running vac on sucktion side of fittings some thing stuck in linerun hose thought it back wash and rinse not waste
Jun 12, 2011 | Hayward SAND FILTER, PRO SERIES
How would I replace my fuel Filter
The fuel filter is an integral component of the fuel pressure regulator, which is mounted on top of the fuel pump module, located in the fuel tank. When the fuel filter/regulator assembly requires service, the fuel tank must be removed from the vehicle, however, the fuel pump module does not need to be removed.
  1. Disconnect the battery ground cable.
  2. You dont have to relieve your fuel systems pressure because your jeep has an automatic bleeder.
  3. Remove the fuel tank assembly.
  4. Clean the area around the fuel filter/regulator.
Fig. Fig. 5: Remove the fuel filter/pressure regulator retaining clip from the top of the assembly
Fig. Fig. 6: Replace the old fuel filter/pressure regulator mounting gasket
  1. Disengage the retaining clamp from the top of the filter/regulator assembly. Discard the retaining clamp.
  2. Using 2 small prying tools, pry the filter/regulator assembly out from the top of the fuel pump module. The filter/regulator assembly will unsnap from the fuel pump module.
  3. Remove and discard the mounting gasket below the filter/regulator.
  4. Before discarding the fuel filter/pressure regulator assembly, inspect the assembly to verify that the O-rings are intact. If the smallest of the 2 O-rings cannot be found on the bottom of the filter/regulator, it may be necessary to remove it from the fuel inlet passage in the fuel pump module.
To install:
Fig. Fig. 7: Check the condition of the fuel filter/pressure regulator O-rings
  1. Clean the recessed area in the pump module where the filter/regulator assembly is to be installed.
  2. Check the replacement filter/regulator assembly to make sure that the new O-rings are already installed on the assembly.
  3. Apply a small amount of clean engine oil to the O-rings.
  4. Install a new gasket on top of the fuel pump module.
  5. Press the new fuel filter/pressure regulator assembly into the top of the fuel pump module until it snaps into position (a positive click must be heard or felt).
  6. The arrow on top of the fuel pump module should be pointed towards the front of the vehicle (12 O&rsquoclock position).
  7. Turn the filter/regulator assembly until the supply tube (fitting) is pointed to the 11 O&rsquoclock position.
  8. Install new retainer clamp (the clamp snaps over the top of the filter/regulator and locks to the flanges on the pump module).
  9. Install the fuel tank assembly.
  10. Connect the negative battery cable.
Jan 28, 2011 | 1996 Jeep Grand Cherokee
Where is fuel filter located on 2005 pontiac grand am?
Removing the Fuel Filter
  • 1 Unscrew the fuel cap. This will relieve the pressure in the fuel lines.
  • 2 Crawl under the vehicle and locate the fuel filter. The filter is located by the cross member in front of the fuel tank.
  • 3 Separate the tabs on the quick connect fitting and pull off from the fuel line. This is the inlet line.
  • 4 Unscrew the outlet line with a crescent wrench. Pull the outlet line off the filter.
  • 5 Unbolt the mounting bracket with a socket wrench. Pull the filter off.
  • Installing the Fuel Filter
  • 1 Bolt the new filter to the mounting bracket with a socket wrench. Ensure the arrow points toward the front of the vehicle. The arrow indicates fuel flow.
  • 2 Push the quick connect fitting on the inlet line of the filter. The fitting will click in place when the line is properly installed.
  • 3 Bolt the outlet line to the filter with a crescent wrench. Ensure the line is snug.
  • 4 Screw the gas cap back on to the fuel nozzle. Close the gas door.
  • 5 Start the car to allow the fuel to circulate through the fuel lines. Listen for any stalling or hesitation
  • Oct 29, 2010 | 2005 Pontiac Grand Am
    I got a used filter queen majestic vacuum at a yard sale and want to fix it up and start with new filters where do i get the filters and how do i change them
    Well you bought a really great vacuum cleaner. The Filter Queen's are extremely durable and very well made vacuums. They sell brand new for over $2500, so picking one up at a yard sale was a great find by you.
    There are several different filters on this model that need to be replaced. Here's a link to a 6 month supply kit that we sell, which contains all the filters needed for a 6 month period:
    Filter Queen MediPure Filters 6 month supply
    The only other part that you should be replaced on a regular basis is the belt (only if the vacuum has a motorized power nozzle for cleaning carpets). The belt should be changed every 6 months or so. Even if it doesn't break, these belts will stretch out and not work as well as a new belt would. Here's a link to the belt that will fit your Filter Queen Majestic:
    Filter Queen Power Nozzle Belt to Fit All Majestic models using a flat belt
    Here's a link to the owner’s manual for a newer Majestic model. This is the only one that is available online. Even though it's a newer model, the maintenance and care will be exactly the same for your model.
    Filter Queen Majestic Owner’s Manual
    I really hope this was the information that you needed. If you have any follow up questions, please don't hesitate to ask them by using the comment box here on the Fixya repair page.
    If this did help you, please be so kind and rate my repair helpful, or leave some feedback for me. This is greatly appreciated.
    Thanks,
    Chris Jones
    GoVacuum.com
    Jun 15, 2010 | Filter Queen Majestic Canister Vacuum
    Need a new electrolux power nozzle model N106m
    If you're looking for a new head for your vacuum. Then you're going to have to replace it with the same type of nozzle.
    However, wall inlets are standard so you can purchase any kind of attachment kit and it'll fit your inlets and work with your system. Their are many online retailers that offer a wide range of kits that will fit your system.
    Mar 22, 2010 | Electrolux Centralux Vacuum
    Belt repair kenmore model 57612690 belt 20-5285
    You can get the belt you need here:
    Kenmore 20-5285 Belt
    Replacing the belt is quite simple. First, push inward on each side of the light cover on top of the power nozzle and it will lift off. You will then see (2) access screws. Remove the screws and then the top cover can be removed from the base of the power nozzle. You can then remove the old belt and replace it with a new one. Hope this helps!
    Dec 07, 2009 | Vacuums
    Will not ignite after replacing air filters
    Clearly a problem with the new filter.
    Does it have a check valve built in?
    Try to get a flow through it without the nozzle attatched - and often there is a small sintered filter attatched behind the nozzle anyway. take off nozzle and try priming (without igniting obviously).
    Could be air in there so needs priming. Often heaters shut down if air is present - so need to be bled of air. If you can pre-fill the filter, or bleed air at a joint just after the filter - this usually works.
    Please rate at Fixya if this solves the problem. - It is free, and I improve my score if you do.
    Thank you.
    Feb 04, 2009 | Reddy Heater-30-55,000 BTU Variable
    Samsung Refrigerator Water Filter DA2900003G DA2900003B Logo
    286 people viewed this question
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
