Error message call service 0150:0000000. what does this mean
  • arnold_moyo Sep 25, 2008
    kyocera that has service 59.0
Error message is 59.c0 , the printer can not print any paper
and you make sound very large
Posted on May 28, 2008
  • hesham May 28, 2008
    plaes can you help me
    with myy respect
I have a kyocera print that has a serviced error .
Posted on Sep 25, 2008
2 Suggested Answers
  • 417 Answers
SOURCE: FS-3900DN Error 0150:0000000
This error suggests eprom error the system firmware will need to but upgraded or reinstalled.
If it is new contact the store you purchased it from and tell them. If not contact Kyocera online and they will (or Should give you a dealer in your area)
Thanks J
Posted on Jan 02, 2008
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
What does an error message E000007-0000 mean for a canon IR2270. Someone is suggesting to replace the laser drive motor?
Error Message e00007 code means that the fusing film is out of Home Postion or the film is ripped. You will need to most likely have the fixing film replaced. You are proble going to have to get a service to repair it.
Sep 09, 2010 | Canon imageRUNNER C3200 Copier
Muratec f320 states: fax ready please call service it continues to send faxes but is not receiving
F-320 "Please call Service".....Press PROGRAM,*,6.....Press PROGRAM to select "Service Call"....error message will now be displayed.
Most common is #02 (Heater Error) which means you have a defective fuser.
Press PROGRAM to show any other error messages.
May 14, 2010 | Muratec F320 Plain Paper LED Fax
Error message E00001*000
It means that you have fixing problems, try to enter the service mode * 2 8 * and under clear select clear err or all.turn off and on. If doesnt help you need to change the lamp or thermistors.
Pls. rate
May 10, 2010 | Canon imageRUNNER 2000 Copier
What doea the tE error message mean?
In the manual it does not have a cause... just shut off the power and call for service...
Feb 12, 2010 | LG WM-2277HW Front Load Washer
Our Jura coffee machine S9 model has error message Malfunction 4 appearing, have turned machine off from power swith and left off for 30 secs, still has same error message.
Hi, Printed below is the fault for Error 4:
STEAM: Temperature sensor notify “value above tolerance”
I hope this helps.
Alison, Uno Coffee Company
Feb 11, 2010 | Coffee Makers & Espresso Machines
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Fujitsu error message
From service manual -
Error message condition one = fan protector operated.
Main Power pcb,
Main digital pcb.
Feb 21, 2009 | Fujitsu (pds42trs) Monitor
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
"Service Req E095"
This is an HSYNC Error and probably means the Laser unit on your machine is faulty.
Possible causes of the error :
Laser Scanner
LSU Harness
C585 Main MCU Board
For more info get a service manual HERE
May 28, 2008 | Epson AcuLaser 2600N Printer
835 people viewed this question
