Oki 7300. yellow toner sensoe error, yellow toner low. Black toner low. I have changed toner on both units and replaced the yellow drum unit as well. the errors will not clear. is there a reset that needs to be done?
  • 857 Answers
This is a problem with toner lock lever
Check toner lock lever is in position - Seek attention of service person if restarting the printer does not correct the problem.
Look into this ink :
http://www.c5200.co.uk/index.asp?menumode=0&content=sensorerror
Posted on Oct 05, 2010
Where is the ATDC sensor
If you replaced the developer unit then you already replaced the ATDC sensor. using third party toner or KMBS? if so use only KMBS
Jul 25, 2014 | Konica Minolta Bizhub C360...
Oki c5550 mfp
i have the same problem with my magenta drum unit on my oki c5550 the screen says missing M drum unit and the other errors i am getting are incompatible toner C,Y,K. how do i fix these
Aug 08, 2013 | Office Equipment & Supplies
Oki C9650 not printing Yellow
remove the unit
open the cleaning lamp cover (front of unit)
turn O.P.C drum gear and check that toner is always applied to the developer roller
Sep 27, 2012 | Oki Printing Solutions C9650 Led Printer
OKI C6100 Printer Error Messages: K Toner Empty Y Drum Life
Needs Black Toner and Yellow Drum
Replace both while printer is on
Feb 10, 2011 | OKI C6100n Laser Printer
Falal error 173 on oki c5650 after changing fuser unit
Cause:
This error indicates that the Image Drum Up/Down Process is not working properly.
The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Resolution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
OKI B4400 toner - is the chip reusable? I get toner not installed
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
Jan 27, 2010 | OKI B4400 Digital Mono Printer - Black
My laser printer used to click when starting up on the yellow toner now yellow does not print at all.
Replace Y toner cartridge (use oki ones or risk it not working for you, but I have warned you now) it was low (sensor clicking) now it is empty(stop operations)
Chances are that you will then need the other colours too, they all go about same time, but depends on what colours you print, normally black goes first then 3 colours, lights and software should indicate but once it is empty totally all will stop...
You can check visually by removing suspect drum and toner, putting on desk, remove toner cart. from top of drum, inside drum running the width of top surface is a 2 x 15cm wide slot, it needs to have the toner to the brim of this slot (foam edged), there also needs to be toner left in the toner unit itself thats sits on top of this slot.
Cheers
Nov 02, 2009 | OKI C5200n Laser Printer
OKI B6300 Drum problem
Hello, com_jedi. I would suggest you contact the OKI Customer Support line in order to address this issue. The phone number is 1-800-654-3282 (800-OKIDATA). For your model unit you would hit options 1 then 4 to get to mono support.
It is possible that you purchased a defective consumable and OKI warranties them for 90 after the date of purchase. If this is a new drum/toner it may need to be replaced to determine if it was a bad chip in the cartridge or if there is some other issue with the unit that is causing the error.
It is also possible there is a misalignment with the sensor that is located under the drum unit. A support tech can walk you through the troublehshooting as it would be a bit difficult to do here.
I hope this helps!
Feb 12, 2009 | OKI B6300 Laser Printer
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
OKI 9800 with "342" error code
problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Aug 24, 2007 | OKI 9800hdn Laser Printer
50 people viewed this question
jasbo
jasbo
