Question about Samsung MW8554W Microwave Oven
MY MICROWAVE OVEN DOESN´T HEAT, HOW MUCH WOLD BE THE REPARATION?
  • Samsung Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. The majority of the time when you have a working control panel and no heat there are 2 - 3 items that fail.
Service manual for this microwave is actually posted on the sears website:
http://www.searspartsdirect.com/partsdirect/part-model/Sansui-Parts/Microwave-Parts/Model-MW8554W/1763/0123245?pathTaken=
Cost will depend on what part has failed.
Kelly
Posted on Oct 05, 2010
  • Kelly
    Kelly Oct 06, 2010
    My apology to you. The manual link is useless. Hopefully one of our other experts has a better grasp on repair costs for this particular model. I do not have the manual for this oven and should not have answered your post. So my ability to extimate cost for this microwave oven repair is expremely limited unless I did an on site / in home analysis of your microwave.
    Just don't rate the post and someone here should respond.
    Kelly
GE profile JE2160SF03 microwave oven doesn't heat
3 things high heat low heat cencor or magnatron is bad
Apr 02, 2013 | Microwave Ovens
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Maytag microwave problem everything seemingly works but does not heat. Help
see this causes and fix it. God bless you
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Oven is not making etables heat
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 07, 2012 | LG Microwave Ovens
Our Whirlpool Microwave Oven makes a loud winding noise and doesn't heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 01, 2011 | Whirlpool MH6150XLS Microwave Oven
Doesn't heat up but everything works
heatman101 ';'
May 18, 2011 | Emerson Black Microwave Oven
How to fix an Emerson microwave 8992RD that carousel doesn't turn and doesn't heat your food..
heatman101
May 08, 2011 | Emerson Black Microwave Oven
I bought I microwave in the USA and I had it installed in my home in Brazil and appers working well but it doesn´t heat. What I could do to solve this problem?
Was it new? normaly when a microwave deos not heat it means the magnetron is dead (that's the part of the oven that produces the microwaves) or it could be a burned fuse, if it's a dead magnetron it is almost as expensive as a new oven.
Jan 04, 2011 | Samsung SMH9187ST Microwave Oven
The microwave oven doesn´t turns on
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 22, 2010 | Microwave Ovens
Power is on, lights and front panel work, just no heat
There are a few definite causes but if you would like to rectify problem without messing around, i wold replace magnatron: capacitor and HV diode.That will certainly sort the problem out.
Sep 25, 2009 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
113 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
