Question about HP Photosmart 3210 Printer
Ink refill I have a HP 110 ink cartridge Tri-color. Can it be refilled and how. I have the ink but don't know which holes to put it in. Thanks
  • 21 Answers
Get a tissue paper smudle the cartridge head on th tissue in a straight line this will give you an idea where their holes are they are the ones directly above that color or that order usually Left to right starts with yellow cyan magenta in a traingle formation it should be in line with the line you produce when you smudge it on the tissue directly above each line is its hole on top of the cartridge..
Posted on May 31, 2008
Refilling procedure
You need to specify what brand is your printer.But the procedure is as simple as dirty. Make sure you have a cloth or paper to handle the messy part :).
Requirements: 1. Printer-Ink 2. Syringe with thin needle3. Piece of cloth
I will write how to refill HP cartridge, because I don't know your model.Ususally Hp cartridges have colored or black spot ont white sticker.Under this spot there is a tiny hole. This hole is designed to be used for refilling. You need to pierce the spot with the needle and start the refilling process.Make sure that there are no bubbles in the syringe and start filling slowly the cartridge. Do not hurry! Don't fill the cartridge to its full capacity. If your cartridge is 20ml fill only 15 or 16ml.After you finish set aside the cartridge for 30 minutes so that the ink settle. This is it!Good luck!
Dec 19, 2011 | Office Equipment & Supplies
I don't know how to refill?
Refilling HP color printer ink cartridges saves money and time spent running to the store to find the right ink cartridge, which sometimes is out of stock. By having the refill kits for the HP ink cartridge, you can just refill the cartridge when the ink runs out. The refilling process is easy to do and anyone can do it in a few minutes. The ink kits come with directions and all the colors one will need to refill the ink cartridge.
1.Place a piece of paper towel on a flat surface. Remove the empty ink cartridge from the printer. To do this, open the cover and wait for the ink dispenser to move the ink to the open door. Lift up the tap that holds the ink cartridge in place and pull out the cartridge. Push the tap holder back down and close the cover.
2.Place the ink cartridge on the paper towel. Gather the ink refilling kit together with directions and place the ink jars on the paper towel along with the syringe needle.
3.Find the indents on the top of the empty ink cartridge. Poke these holes open with the pen. Sit the cartridge down and open the ink containers. The colors are yellow, cyan and magenta.
4.Read the directions to see where each color goes in the ink cartridge. Insert the syringe needle into the ink container and raise the stopper up until you have the recommended amount of ink to fill into the particular hole.
5.Insert the needle into the hole on the ink cartridge and slowly dispense it into the cartridge. Remember to go slow with this step. If you see the ink oozing out, stop filling and wipe with a paper towel.
6.Cover the holes with the tabs that come in the refill kit or you can use tape. Make sure the hole is sealed to prevent spilling or the ink drying up. Then replace the ink cartridge back into the holder in the printer.
I hope you find it very helpful. Thank you for using fixya.
Aug 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
How to refill HP 802s tri-colour cartridge
Remove the sticker label of your cartridge the you see a three small hole, each hole have an appropriate colors for the cartridge. Fill up the syringe with ink that compatible to your printer then infused it in the small hole in your cartridge with the same color that you have filled in in the syringe. Do it same in the other colors. If the syringe not fitted to the small hole make it a little bit bigger with same size of the needle of your syringe. Put a absorbent paper in the cartridge where the ink is leaked. Don't mind it if it is leaked it is normal. Before returning it to a printer be sure that the terminal of the cartridge is not wet by the ink that you fill in the cartridge. Hope can help you
Jul 12, 2011 | Computers & Internet
How to refill hp 802 tri color ink catrage? please tell me
if you want to refilling yourself then your requirments must be syringe, ink
you have to take ink in the syringe and push the ink in the sacific point in the cartridge. you have to remeber that you should diffrent different syring fo different colour
thanks
Jun 22, 2011 | Computers & Internet
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Ink cartrige problem
This is error is common after a cartridge is refilled, in most cases it's because of "bad refill" and we can also say "dead cartridge". If possible, Please try the cartridge on another printer or try your printer with another cartridge. (i hope you know what tri color mieans = the color cartridge). Make sure the cartridge is not overflowing or leaking. Clean if possible, and never touch the print head, if you ever did so there's no way to make it work again. Hope this helps. Good luck Thanks for using FixYa.
Jun 01, 2010 | HP PSC 1510 All-In-One InkJet Printer
Ink cartridge refill
Was there a sticker over the holes? One way I usually find out is by looking at the bottom of the sticker to see the color residue.
May 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
What colors go where in hp 93 for refills
Maybe this picture might give you some guidance:
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | HP OEM HP 93 Tri-Color Inkjet Print...
Hp 57 tri colour cartridge refill
wrap the tip of a straight pin with a little cotton and stick in the hole do this for each hole with new cotton each time of course.
Jan 28, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
HP 95 Tri color inkjet cartridge refill
Yellow Top
Megenta, Bottom Left
Cyan, Bottom Right
(leave the middle two holes alone)
Jan 05, 2008 | Office Equipment & Supplies
HP Photosmart 3210 Printer Logo
102 people viewed this question
Seeker5211
Seeker5211
