Question about Polaroid FLM-323B Television
I am having lines running through my TV and It got worse, now the colors are all messed up. When i shut it off for awhile and turn it back on, it seems ok, a few lines but color looks good. After about 10-15 minutes later the colors go all crazy.
  • 120 Answers
The problem you are experiencing based on the symptoms all point to the T-Con board. This board is located right above the panel, it controls the cells of pixels on the screen. What happens is once this goes bad you will normally tend to have lines on the screen as well as psychedelic colors. To replace the board does not take very technical skills but there is a lot of screws in between so I would recommend taking your unit to a certified repair center to have this board replaced.
Posted on Oct 05, 2010
  • earlppike Jan 11, 2011
    i am having the same problem when it gets warm at all the lines come in sometimes letting it cool off helps sometimes it dont.... how much is the t-con board cost and above what panel is it?....
    frustrated tv guy.....
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
I have fixed many of these polaroid tvs and it seems like the capictors on the power board are going bad. This is caused by wear and tear and if you dont know how to work on tvs this might be one for the repair shop. It also sounds like some heating issues I would make sure it gets good ventialtion and check around the tv for any plugged vents on the back or around the sides. If you get a fan that can be set up to blow on the back of the tv this might help it last longer before it starts messing up.
Turning off then turns back on.
The ballast board that controls the lamp is bad.
Feb 20, 2014 | Vivitek V37655 56" DLP TV
In the past, turning off and on would result in "blinking power light" situation. I would unplug for 10 minutes, and all would be well. But suddenlt, powering on just show a mess of RGB colors...
The tv board that call the HYPER board nown as the tv convergence board was dying and have problems,but the tv was still used able that why u able to unplug it awhile,replug it back and get it up and running.Now the tv HYPER board known as tv convergence board are totally dead,colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures for a minute when the HYPER board was still functional for a little bit.Now the tv HYPER board getting no voltages at all,that why ur tv getting only a power LED indication light flashing only.The tv must get it tv HYPER board fixed also known as a tv convergence board.The tv HYPER boad must have it parts replace like 2 STK convergence ICS and some or all of it resistors too.To get the tv up and running again.The tvs shops will cost u like $300-350 for parts and labors.
Aug 10, 2011 | Toshiba 55H70 55" Rear Projection...
We have a Samsung DLP about 5 years old. We noticed that the fan or some sort of hummning sound was coming from the back louder than normal while TV is on. Then suddenly the picture would start to freeze...
This tv have a colors wheel,hear loud motor noises,humming noises,squiling or grinding noises,have pictures black and white.All these causes are by the colors wheel is worn out, warp rubbing against it motor or fiber plastic glass briddle about to brake aparts.Don't turn this tv on anymore until,u change the colors wheel or u will damage the projection engine.The colors wheel are hard to change for amatur and hobiest.Because involved taking out many machanical parts,before even can come to the colors wheel to take out and change it.The best course to to hire a Tv Tech.to do this job.The price colors wheel part and labors.Awhile back was about $500-550,now??
Sep 10, 2010 | Samsung DLP HL-P5663W 56" TV
I have a symphonic tv. when you turn the tv on all i get is one color line across the top of the tv. if you mess with the cable in the back the picture will come in.( i disconnected the cable and still...
Hi,that is comme from your cable connector in the back off the tv /or its could be the tunner its self having a bad solder where its conecting pinfrom cable in to inside the tunner/pr or try another cable conector,
hope that help you
thank to ask fixya..
Mar 31, 2010 | Televison & Video
Glitchy picture with lines across screen when turned on
I can give you detailed guide describing exactly wich capacitors to replace . Your tv really only needs maybe 5 dollars worth of parts. But you must know how to solder and take things apart . also you must be able to put it back together. if only there was some way you could paypal 50 buck to me.;(
Oct 04, 2009 | Toshiba 50HX81 50" Rear Projection...
NEW TV WONT TURN BACK ON
polorid known for going out take it back asap those have worse revies back panel go out ok no good please upgrade yourself to a nice samsung or sharp ok for best quilty for yrs to come u be happpy u did
Jan 29, 2008 | Televison & Video
Polaroid FLM-323B Television Logo
623 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
