Question about Acer X233H 23" Monitor
When I push the on button nothing happens as it seems to be stuck ih the off position and had to go and buy another Acer monitor !!!
    Sergeant:
    Champion:
  • 293 Answers
Deffective power supply of your monitor.Need for repair and trobleshoot
Posted on Oct 06, 2010
My aspire ast180-ea 350b won't power on
This sounds as though the power supply unit within the desktop has failed.
You should be able to buy a standard replacement from your local computer repair shop.
Dec 10, 2013 | Acer Aspire Computers & Internet
Bosch Dishwasher won't fill with water
Certainly *sounds* like the float is stuck in the over filled position
or possible a bad float switch, if the float is stuck in the up or full position, the d/w will not fill with water and the drain motor will often run all the time
Jan 23, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
My acer monitor H243H says No Signal after I unplugged the DVI cable and plugged it back in. I can't switch the input because nothing happens when I push the input button on the bottom of the monitor. It...
Maybe your BIOS switched to VGA output, try plugging in another monitor which has VGA input and change settings in BIOS for default output to DVI.
Nov 05, 2013 | Acer H243H Monitor
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
Power button stuck down..
all i could suggest would be to check with a repair shop on replacement parts or something.
Jul 20, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Cannot raise vertical height after pushing button on back of monitor (button stuck in)
With the monitor in the lowest position, push down slightly on the monitor and push the button in. While holding the button in you should be able to raise the monitor with your other hand. This worked on the one I have.
May 01, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Black screen
If the light stays on for longer than about 20 seconds, try moving the lid back and forth, try positioning it in every possible way. If you get an image, even for a second, you need a new LCD cable. If nothing happens, try to get your hands on an external monitor. Plug that bad boy in, if you get the image, you need either a new LCD cable or a new LCD screen. If still nothing happens, then you probably need a new motherboard.
Before you go buying a new MB/LCD/LCD cable, which can be rather costly, open up the back and make sure the RAM is seated properly, sometimes something can jar RAM sticks loose.
P.S. DON'T FORGET TO VOTE
Apr 15, 2009 | Acer Aspire 5050-3371 Notebook
The menu that controls contrast, brightness ect is stuck on the menu and when i push the number 1 button on he monitor it does nothing but lock the osd. If i hit the down button the contrast will move down...
Try pressing the number 1 again. It should exit the OSD. While the screen is stuck with the OSD. Press the power button (blue) and push to turn it on again.
Hope this helps.
Mar 15, 2009 | ViewSonic VX924 19" LCD Monitor
Vertical positioning setting is frozen
lets see what i can do
sometimes under the screen edge either side or bottom they have the menu buttons these have become hard to find but there on your screen on one of the buttons the select should be de gaus (spell check) this sends a powerful power signal to monitor to reset its self some times its scary to watch but when it does that it should release the buttons parameters back to working state then use the buttons to set your parameters
the other thing is there is something stuck or broke in the button which was pushed a little harder then most
if this is the case
and you dont want to mess with monitor then take to computer tech. they will tear down and replace button backing sometimes the button backing points break off or disalign do to tomuch preasure on the button
i hope this helped you
May 25, 2008 | Acer AL1715 17" LCD Monitor
Monitor
OPEN MONITOR , look inside the PC BOARD around the transformer area and look for a burnt solder or cold solder , re solder it , and try again , please rate solution , thanks AJ
Apr 28, 2008 | Acer AL2216W LCD Monitor
Open Questions:
Acer X233H 23" Monitor Logo
177 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
