Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Como programo el congelador de un bosch intelligent frost free 44
SOURCE: bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Posted on May 12, 2009
  • 87 Answers
SOURCE: How do I change the
reach behind the flap and pull on it .
Posted on Jul 12, 2008
  • 3 Answers
SOURCE: Bosch intelligent frost free 44
there is a drain hole in the freezer dept in the fridge that is blocked This requires removing all the panels etc within the freezer until you get to the main grill at the back This will be iced up so you might have to wait a while or you might be able to chip away at it. You will then see the drain hole concerned at thre bottom Try pocking a thin wire down it or poor hot water over it Its a bit of fiddling around but is not hard to clear Problem solved
Posted on Feb 28, 2009
  • 1218 Answers
SOURCE: Can 1 de-frost the intilligent 32 & let it stand open 4 a month?
Yes. I recommend using a floor fan (20" model) to dry them out as well with power to the units totally disconnected. One of the important reasons is because power outages to your residence while you are gone can create problems with the units, especially voltage spikes. Any period in excess of a week, unless you have someone to baby sit qualifies for this proceedure.
Posted on Oct 25, 2009
SOURCE: Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Posted on Feb 24, 2010
Compr? un Radio Kenwood KDC-X300,cuando programo la hora,la fecha,dem?s funciones,apago mi carro,lo vuelvo a prender,el radio aparece en standby┬┐?lguien de ustedes me podr?a dar una respuesta?
Mi Espa?ol no es my biene ,perdone. Suena Como que lo tiene connectado all ignition solamented. Se nececita conectar el alambre de Acc. A la batteria directamente Para que Guarde la memeoria . Ay beses que se Idica el alabre en question con color azul. Hope it helps Buena suerte,
May 16, 2016 | Cars & Trucks
Necesito el codigo de un television de marca Pixel
Quien me puede ayudar con un video sobre el menu de pantalla de una tv marca pixel ya que por error quite todo brillo luz color y no la puedo ver
Feb 10, 2014 | Televison & Video
Tengo un control rca y una television Dj master como la programo
Programaci?n del RCA remoto.
Se tarda s?lo unos pocos pasos para programar un control remoto universal RCA utilizando el m?todo de b?squeda autom?tica de c?digo. Bien puede haber algo de ensayo y error, pero el placer de deshacerse de varios controles supera la inconveniencia en conseguir el c?digo. Siga estos consejos cuando programas un control remoto universal RCA.
  1. Prenda la televisi?n que desea controlar.
  2. Presione y mantenga presionado 'CODE SEARCH'.
  3. Presione y suelta el bot?n del 'TV'.
  4. Suelta el bot?n 'CODE SEARCH'.
  5. Presione el bot?n ON/OFF repetidamente hasta que la televisi?n se apaga. Puede que tenga que hacer esto hasta 100 veces.
  6. Cuando la televisi?n se apaga presione y suelte 'ENTER'.
    Trate de usar el control remoto. Si no funciona repita los pasos 1 a 6.
Jul 07, 2011 | Computers & Internet
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
May 12, 2011 | DISH Network IR Remote Control
Como programo el control de un dvd recording DMEES-15
Hola,
Quisiera saber si tu control remoto es el original de la Panasonic o es Universal?.
Gracias
Feb 20, 2011 | Panasonic Computers & Internet
Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Feb 17, 2011 | DISH Network IR Remote Control
HOLA SOY SANDRA, TENGO PROBLEMAS CON MI REFRIGERADOR WHIRPOOL WRT 18AEC EL CONGELADOR NO SE APAGA ESTA PRENDIDO DESDE AYER, Y NO ENCUENTRO EL MANUAL. ME PUEDEN AYUDAR . MUCHAS GRACIAS
Hi!! Primero asegurate que el control de la temperatura del congelador este aproximadamente en el numero 3. Cuando dices que el congelador no se apaga, quieres decir que el ventilador del congelador esta prendido siempre, correcto? Si el ventilador esta prendido, el compressor y el ventilador que estan abajo, detras del refri tambien deben de estar prendidos chequea por favor. Si esto es correcto, desconnecta el refrigerador por unos 20 min. y luego lo connectas de nuevo, esto hara que el timer se haga reset, si ese es el caso, el problema se solucionara. Si no me envias un comentario y tratamos algo mas. Estuve buscando un manual para tu unidad pero no he encontrado ninguno en espanol, voy a seguir buscando.
Si le haces click en este link, te va a llevar a donde esta un diagrama de las partes the tu unidad, si tenemos que tratar algo mas, te va a ser util para saber cuales son las partes y sus nombres y me puedas entender mejor. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Parts%20List%20(SP)%20-%20WRT18AECLM00.pdf
Avisame lo que pase por favor.
Jan 11, 2011 | Refrigerators
Como programo un dvd player sonny
Hola mi nombre es Kimberly Escobar soy representante de Dish Network servicio al cliente. Estoy respondiendo a su pregunta para ayudarle y proveerle la informacion necesaria para programar el control con su DVD. Hay ciertos codigos que tenemos que integrar al control para que pueda funcionar con el DVD por ejemplo unos de los codigos serian 731, 501, 617, 500, 117, y 671. el procedimiento es el siguiente: en la parte de arriva de su control va a oprimir el boton de AUX hasta que los demas botonos se iluminen en rojo una vez esto suceda usted va a ingresar un codigo (antes de el codigo siempre va un numero 1 primero por ejemplo si usa el codigo 731 enrealidad seria 1731) seguido por el signo de numero (#) por ejemplo 1731#. el boton AUX deberia iluminarce en rojo 3 veces, despues de esto puede intentar usar el control con su DVD. Desafortunadamente no le puedo prometer que funcione pero el definitivamente el procedimiento a intentar. Si tiene preguntas o necesita mas ayuda por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le ayude.
Sep 30, 2010 | DISH Network IR Remote Control
Como programo la caja del dish
Hola mi nombre es Mayra Diaz con DISH Network con mucho gusto le puedo ayudar a programar su caja de DISH. Si por favor me puede dar mas detalles de lo que pasa como el modelo de la caja, es un recibidor nuevo? Ya teniendo estos detalles le puedo asistir con un mejor conocimiento.
Aug 04, 2010 | DISH Network IR Remote Control
QUE TAL SOY CLAUDIO BERTON DE MENDOZA ARGENTINA, I MAIL claudio.ugarcop@speedy.com, SE DESCONFIGURO EL CODIGO DE ENCENDIDO DE LA LLAVE Y NO CONTAMOS CON EL CODIGO MAESTRO, NI OTRA LLAVE DE EMERGENCIA de...
Saludos Claudio:
Sugiero visitar al representante de la marca; esta es muy especifica y no existe informacion de referencia en el Web acerca de este tema. Lo siento.
Iveco Assistance Non Stop ofrece tanto la asistencia en ruta como el traslado del vehiculo hasta el concesionario mas cerca.
Con solo realizar una llamada telefónica 0800-44- IVECO o 0800-44-48326 , profesionales calificados asisten al instante el vehiculo.
Además si el vehiculo esta en garantía el servicio es completamente
gratuito y con prioridad de reparación en el momento del Service.
Suerte.
Mar 09, 2010 | 2000 Chevrolet Tracker
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
126 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
