Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
How check for proper coil out put on a poulan chain saw
  • 7,733 Answers
I gallon of gas and a 7.5 onz (small bottle) of 2cycle oil.
Posted on Oct 05, 2010
There's 2 sets of numbers on the coil. The top i know is a part # but not sure about the bottom it's MA-15 1435 it's a Walbro coil
Rick, easiest just to order a coil by using make and model # of the chain saw.
MA 15 does show up a replacement Walbro coil.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Chainsaw Ignition Coil Test
Poulan Chainsaw Ignition Controls Parts
Poulan IGNITION COILS
Poulan
Apr 18, 2016 | Poulan Garden
I need coil assembly for craftsman chain saw 358.35060 . PART NUMBER: 39078
Husqvarna bought out pioulan so if you have a poulan part number put a 532 or 531 in front of that number and you should be able to get the part from husky
Aug 29, 2014 | Garden
The chain keeps falling off my brand new Poulan sixteen inch blade chain saw
It is possible they gave you the wrong chain for the saw. I would take check the manufacture to see which chain you need then check the numbers on your chain. Other thing it could be is the washer on the clutch may be missing. Either way, it is a new saw, I would take it back.
Apr 01, 2013 | Poulan Garden
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Proper spark plug gap for poulan chain saws
I believe the proper spark plug gap for poulan chainsaws is .025-inch. That goes for all units.
Aug 22, 2010 | Poulan Pro Chain Saw 46cc 20"
My poulan saw keeps stalling and has no power
Check the fuel filter, air filter, and muffler for clogging. Check the fuel lines for condition. The carburetor may need cleaning and re-kit. Make sure the chain is being properly oiled and sharpened. Good luck!
Jun 10, 2010 | Poulan PP4218AV 18" Chain Saw
What is distance from coil to stator 14 in. poulan chain saw
I think you are asking for gap between the fly wheel and the ignition module. A business or index card works great. 0.1 - 0.3 mm. GL
Lou
Oct 09, 2009 | Poulan Pro Chain Saw 46cc 20"
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
70 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
