Question about Kitchen Ranges
Doesn't work. Shows F3 and F4 - Kitchen Ranges
  • Kitchen Ranges Master
  • 3,051 Answers
Hello there:
the f3 or a f4 error code is referring to the temperature sensor that is shorted out and needs to be
replaced looks like this
Posted on Oct 05, 2010
How do I turn off backlit keyboard
Hi! Usually it is Fnc + F2 or Fnc + F3 or Fnc + F4. Check it out! (By Fnc I mean the "Windows" key on the low left side of your keyboard)
Jan 27, 2015 | ASUS K52F-BBR9 Notebook
At work we have molder ge drop in stoves and we are getting error codes f3 f4, then oven turns off
f3 and f4 are temperature sensor faults. check the thermometer sensor in the oven.
Dec 14, 2014 | GE Kitchen Ranges
Buttons dont work
You must have one of the newer OS versions (MP 2.53 and higher). You don't have anything under F5.
Feb 05, 2014 | Texas Instruments TI-84 Plus Silver...
HOW DO I BATCH OUT
GETI CHECK SALE [F2]
PAYROLL/BUSINESS [F3]
MORE VERIFY ONLY [F4] Press the Purple key below the More option. GETI CHECK SCANNER MENU [F1]
BATCH MENU [F2]
REPRINT [F3]
MORE VOID [F4] Select Batch Menu [F2]. ERASE BATCH [F1]
CLOSE BATCH [F2]
HISTORY REPORT [F3]
BATCH REPORT [F4] Select Close Batch [F2]. KEY IN MANAGER PASSWORD
AND PRESS ENTER Press [1] and [Enter]. ARE YOU SURE? CLOSE BATCH [F3]
CANCEL [F4] Select Close Batch [F3]. DIALING . . . The terminal will dial in to close the batch. Once closed, the terminal will print the batch report indicating Batch Accepted.
See example below. BATCH ACCEPTED
EXIT [F4] Select Exit [F4] to return to the menu.
Oct 19, 2011 | VeriFone VX510
Range displays code of F4 and stops working
F4 Oven temperature sensor (RTD) shorted Replace Oven temperature sensor (RTD)
The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
Hope helps.
Jun 14, 2011 | KitchenAid Kitchen Ranges
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
I have a GE space maker xl1400 model 1410bc001 it is beeping & displays F3 or F4 what does the F3 or F4 mean
F3 or F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 02, 2010 | Kitchen Ranges
F2 F3 and now F4 error message
F2 is oven temp too high
F3 is open sensor OR thermal fuse
F4 is shorted sensor
1.Check the thermal fuse
2. Check that the sensor is installed properly.
3. install new sensor.
Apr 27, 2009 | KitchenAid KESC307 Electric Kitchen Range
On the screen it shows F4, and F3
F4 means an open humidity sensor, but sometimes this error is bogus and can be reset by unplugging the oven for a minute or so.
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller † prototech@usa.net
http://www.microwavedisplay.com
Oct 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a whirlpool catalyst washer and recently it started blinking an F4 error code..my ? is what should I be looking at when it shows that error code?
what is your model # i looked at the manual there is no F4 code they only go up to F3 if you post your email i will send you the service guide
May 20, 2008 | Whirlpool Washing Machines
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
