Question about Maytag Atlantis MAV6000 Top Load Washer
My Maytag washer MAV5920EWW is not working after power outage. The lights around the control knob flash twice every 15 seconds. When I press down the control knob to start the machine, it works until the lights flash again. I tried unplugging and re-plugging or turn it off, but nothing I tried so far can reset it. A technician checked it and said the control board needs to be replaced. Is there a way to reset it? Thanks a lot!
    President:
  • 1,554 Answers
The technician is right, the control board needs to be replaced. No such reset button for the control board. The only way it can possibly reset it is unplugging it for longer period to forcibly reset the microcontroller but there's no assurance that it will reset. Let the machine sit overnight before purchasing a new control board with part number 21002238.
Posted on Oct 05, 2010
2 Suggested Answers
  • 619 Answers
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Posted on Jan 09, 2008
Bocsh 1400 express f21 keeps flashing
This Bosch looks like a Kenmore HE2, and may be made by the same manufacturer.
In the Kenmore HE2 manual it states:
"F" Variables [F4 to F16] (Electrical problem)
Select PAUSE/CANCEL twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call for service.
If it's not working still, try asking advice at RepairClinic.com . They have helped me in the past, and they have parts too.
May 29, 2014 | Kenmore HE2 Plus Front Load Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
No codes given control light flashing on selector knob but machine will not start
Hello & Welcome to FixYa
Your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Feb 08, 2011 | Whirlpool GHW9100L Front Load Washer
Have a maytag mav5758eww washer. When I press the cycle selector dial the machine starts runs for about 20 seconds and then shuts off with all control lights blinking on then off.need help - 6 grandkids...
Same thing happened to us after a power outage; repair guy diagnosed it as a fried circuit board; he replaced it and good to go - parts plus labor around $180.
May 15, 2010 | Washing Machines
DOMETIC RM 7651l HAVE POWER AND GAS TO THE FRIDGE BUT WONT START (TWO MONTHS OLD)
Igniting a Dometic gas fridge
    Electronic Ignition
    1. Open gas cylinder or pressure regulating valve
    2. Turn on Electronic ignitor switch
    3. Turn gas control knob to the MAX position, press and hold down
    4. After ignition, hold down knob for a further 15 seconds before releasing. The neon light will stop flashing
    Piezo Ignition
    2. Turn gas control knob to the MAX position, press and hold down
    3. After approximately 10-15 seconds
      press Piezo knob several times until pilot light a lit
  1. Check the Pilot light is alight
  2. The flame can be controlled by aperture ©
    Should no ignition occur, repeat the ignition process after 1 minute
    (This could take longer than 10 seconds if the unit has been out of operation for a prolonged period or after replacing the gas cylinder. (Cause: air in the lines)
  3. Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
I hope this helps you...
Regards
Wouter...
Sep 30, 2008 | Refrigerators
Maytag Dishwasher flashing lights
I have the same problem with the lights flashing on the control panel. It pops up every 4 or 5 months. The only solution I have found is to press the delay/resume button one time then press the drain/off button twice. You may have to hold the keys down for a couple of seconds. This seems to reset something in the panel. Make sure you haven't pressed the 3 second lock button or it won't work.
Mar 17, 2008 | Maytag MDB7100AWB Dishwasher
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
235 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
