Question about Canon ImageRUNNER 330s Copier
E000583-001 error on canon imagerunner
Hello. I'm having this same issue. Is there any chance you could help? We're at a k-12 school and this is our main copier. Thanks.
  • 86 Answers
Hi guildmaker
I would love to help you but you need to supply me with the exact model number and make of your copier.
A E000583 code relates to your sorter/finisher
check the communication lead from the sorter to the copier and if it has a seperate power lead check that its plugged in.
you can phone me direct on 07764303923 if you are in the uk
or 00447764303923 if outside the uk
please remember to repost with make and model of your machine
Thank You
Posted on May 28, 2008
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from
Nov 05, 2015 | Office Equipment & Supplies
Hello sir i am getting error on Canon irc3170 errror code 0020-01a8 ..... it was working fine but when i filled yellow and magenta tone since then i am getting this error code i think i ned to clean atr...
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
XXA8= In ATR control, the detected T/D ratio is upper than its upper limit (13%) 3 times
in succession.
Check on toner leak from toner buffer in the developing unit, Replace the ATR sensor
imageRUNNER C3100 / C3170
Jan 09, 2018 | Canon ImageRunner C-3170I Copier
its ITB HP detection error.
Possiblle solution is to clean/replace the HP detection sensor and/or detection sensor seal.
The best solution is to call service...
Jul 27, 2011 | Canon imageRUNNER C3170I Color Copier
System error E000.The buttons are locked
this is error related to fixing temperature. If there is no fault in fixing section ( lamp, thermistor, ... ) it can be cleared by service mode.
Press Additional function key ( * ) and # on keybord, by the arrow + go to the #12 CLEAR, press OK and choose ERR and OK.
If the clear can't help You, that means that you need to remove fixing unit, find the faulty component and replace it. It's probably faulty heater lamp.
Hope that helps!
Jul 25, 2011 | Canon imageRUNNER 1600 Laser Printer
My Canon iR 2010 is displaying System error E000; I therefore need to know how to cancel the error i.e. the buttons to press so as to clear the error. Thanks in advance.
thanks a lot , i can clear by your solution and i press *function and # and arrow to #7 press ok and #4 printer reset press ok
May 02, 2011 | Canon imageRUNNER 2010F Copier
getfile.asp?rid=1258 April 12, 2007 getfile.asp?rid=3215 Product : iR6800
iR6870 Title : E070 Problem :
E070 error code.
Sensor reflectors on the inside of the ITB become dirty and do not reflect the light properly from the home position sensors.
Note* - If the equipment is not properly serviced, in regard to filters, the equipment filters can clog up and cause stray toner to build up in the ventilation area. If this occurs, there is a chance that HVT2 can become contaminated and copy quality issues will occur.
Additionally, soiling the white ITB patch may also occur causing E070 error code.
Solution :
Clean the reflective surface inside the ITB or replace ITB.
In regards to filters - Be sure ALL 6 Filters are replaced and/or cleaned at it's proper intervals. If ALL 6 filters are not addressed, poor ventilation will occur and toner can contaminate HVT2. If contamination of HVT2 happens replace HVT2.
HVT2 = FM2-0528-000
ITB = FC5-1658-000 Canon USA, Inc. Systems & Technical Support Division
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
E000 error message on canon imagerunner 2000 copier
E000 means :
"The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
Jan 19, 2009 | Canon ImageRunner 1600 Copier
Imagerunner 7200 Error E0000532-0001-need help!
hello you have to check the stapler unit and exactly the door loock from bottom under the stapler unit
Nov 10, 2008 | Canon imageRUNNER 7200 Copier
Canon Imagerunner 3570 error code
if u r still having this problem with the imagerunner 3570 u can try this:
press * 2&8 together then * again
go to function
then to clear
select eroor then ok that should take care of ur issue
Jun 08, 2008 | Canon ImageRUNNER 3570 Copier/Printer
648 people viewed this question
old marine
old marine
