Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
There is water pouring out of the snorkal on my kitchen sink every time I turn the dishwasher on. How can I fix it?
  • Maytag Master
  • 3,051 Answers
Hello there:
There are 2 possible reasons this is happening .
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Posted on Oct 05, 2010
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
if you have an air gap vent in the kitchen sink plumbing then make sure it is clear. Also looks like the kitchen drain end is blocked. Pour some caustic soda into the sink drain, wait 10 minutes and run water into the sink.
If you are using insinkerator (garbage disposer) in sink, make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
My dishwasher does not drain. Can I use drano?
No, I would not advise using Draino in a dishwasher...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 04, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
No water coming in after sink blockage
Sounds simple , but the plumber may have shut the dishwasher water off. Valve is probably under the sink or near the machine in the basement or crawl space. Good luck.
Jul 04, 2009 | Asko 1385 Dishwasher
Dishwasher water keeps backing up into kitchen sink then taking a long time to drain from sink
Yes, your sink drain needs cleaning -- it's clogged. Pour some bleach into the sink drains and let it sit for a couple of hours. Flush out with boiling hot water.
If this improves the situation but not completely solving the drain problem, try it again.
If that doesn't solve the problem, remove the P-traps on the sink drains under the sink and clean them out.
If that doesn't work, let me know -- we'll try something else.
May 05, 2009 | Dishwashers
No water into dishwasher
I had the same issue s when I drained my hot water heater. I poured a few quarts of water in the bottom of the washer, and started it. Worked like a champ ever since.
Feb 01, 2009 | Siemens 24 in. SL84A305UC Built-in...
Dishwasher draining into kitchen sink!
Is the water coming out the holes of the airgap "vent". If so, you have an obstruction from the hose that goes from the "vent" to the garbage disposer and is causing the drain water to back up. __________________
Jan 12, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Water backing up into kitchen sinks
assuming your dishwasher drains into the trap coming down from the sink, you would need to check the S trap located there.
Oct 23, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Water won't stop entering the dishwasher
SOUNDS LIKE YOUR WATER INLET VALVE HAS FAILED,,REMOVE BOTTOM PANEL AND REPLACE,MIKE
Sep 13, 2008 | Frigidaire 24 in. FDBB840DC Stainless...
Broken dishwasher
If there is no water in the dishwasher - i.e. it had finished a cycle, but now it is just the indicator lights that are on, then the chances are some water has got into the control system. It will probably dry out, given time. (maybe a number of days.)
If there is water in the dishwasher -i.e. it was part way through the cycle and stopped, it maybe that the outlet hose/pipe has got blocked - possibly by your plumber's efforts. Generally speaking, the fats are rinsed off by the hot water, but go solid further along the pipes, as it cools. It could be he has unblocked the sink drain side of things, but not the dishwasher drain pipe. Risking more water on the floor, if your flexible waste hose can be removed, pour some water down the waste pipe, see if it goes away fast enough.
One thing worth trying, if not done so, is to unplug it from the supply, and leave unplugged for 20 minutes or so. Then plug it in and see if it operates OK then. Maybe try that first.
Jan 15, 2008 | Dishwashers
Kenmore ultra wash dishwasher model665
You have a restricted drain in your sink, not the dishwasher. Water is unable to go down drain fast enough and is backing up.
Nov 13, 2007 | Dishwashers
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
166 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
