Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Black vertical line on screen - Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
    Scholar:
  • 30 Answers
Hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Posted on Oct 30, 2010
  • 579 Answers
SOURCE: black vertical line on p42w34p plasma
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Posted on Dec 31, 2007
  • 50 Answers
SOURCE: black vertical lines on flat screen
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
Posted on Feb 03, 2009
  • 1039 Answers
SOURCE: black line going vertical through portion of
Connections on c boards, c board bad or bad panel. Disconnect power supply from sus boards on sides before attemting to disaconnect connectors from c board to flex cables. arc from stored energy on power board will burn cables. reseat the connector closest to the bar . reconnect power supply. Next replace that c board by strip. next replace plasma panel.
Posted on Dec 06, 2009
  • 53 Answers
SOURCE: my kdl46z4100 has vertical black line on the screen
Unless it is spot on dead center of the set, you need to replace the LCD panel. In these models, the suspected TCON (time control) board might do the trick, but I've yet to have success with that board fixing a vertical line issue.
Hopefully you are still under manufacturer's warranty or have some kind of extended warranty, 'cause the price of that panel exceeds $1,500.00.
You could give a shout to Sony customer relations in the event you don't have a way to get the part paid for. Sony may ask that you pay for an estimate, in return for covering the part for you.
Posted on Jan 22, 2010
Testimonial: "Exactly what I wanted to know. Thanks."
SOURCE: appears a black line vertically on the screen
i have vertical lines on screen
Posted on Sep 13, 2011
Black vertical line down Sony TV screen
that isa capacitor at vertical area mostiy 1000 uf to 22000 /35volts
Sep 03, 2014 | Televison & Video
Black lines screen vertical
It sounds to be a COF fault. If you wish to get more details, check the site linked here. Pull up older posts. It has screen-shots to defective plasma and LCD TVs, along with some details to locate the faulty section.
Dec 01, 2013 | Televison & Video
Toshiba 32sl410u have 2 vertical lines on screen
Likely a shop repair but:
Either a bad board (main, or power or even a inverter board)
Worst case if Black line and thick would be the panel (screen unit) which would be fatal but is not likely if lines not black.
Apr 05, 2012 | Toshiba 32SL410U 32 LCD TV
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
238 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
