Bosch exclusiv F 1100 A
We've had this washing machine for about 11 years and has been excellent but recent it has stopped moving to the rinse cycle. We get round this by manually moving it to the wash cycle again without soap and then moving it onto the final rinse cycle. I've check the inlets at the back and the filter and the front base, all were clean and clear. Can you help?
4 Suggested Answers
COXY
  • 76 Answers
SOURCE: bosch exclusiv f 1100
I would check your hot fill hose if it has one, put the programme on a number two and listen to hear any water coming in.
Posted on Dec 05, 2007
57 varieties
  • 1653 Answers
SOURCE: bosch excel 1200 express will not rinse,drain or
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 26, 2009
  • 3289 Answers
SOURCE: which of the 3 dispensers
You can read the manual here.
In short page 15 describes the chambers as follows:
  • The chamber marked "I" is the prewash detergent.
  • The chamber marked "II" is the main wash detergent.
  • The chamber marked with a flower like icon is the fabric softener.
Page 14 describes how to prepare for your first wash by running it without clothes for the very first time to remove water left inside from the factory during testing. Do not skip this important step! You only have to do this once.
I hope this helps & good luck! Please rate my reply. Thank you.
Posted on Apr 06, 2011
Testimonial: "this was so helpful and 'to the point' whereas other web sites gave me a roundabout course and couldn't even print the text. thank you"
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine don't makes the spin dryer at the end of washing cycle
This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 21, 2013 | Bosch Washing Machines
My bosch exclusiv washing machine which is 8 years old has stopped spinning the clothes, they come out soaking wet.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 26, 2011 | Washing Machines
Washing machine stops before rinse cycle
have you checked on the machine internally if you have a borken fuse near the control board of the washer? many times, of age, this part can be rusted and damaged, thuis needs replacement on some parts, and cleaning on most part.
what is the exact model of your wahser, so that we will be able to provide a diagram on where you may check the issue.
Sep 16, 2008 | Washing Machines
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch exclusiv f 1100
Dec 04, 2007 | Washing Machines
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
1,088 people viewed this question
Top Washing Machines Experts
