Question about Grohe Plumbing
My grohe shower faucet wiggles, how do I tighten up again?
4 Suggested Answers
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
  • 2692 Answers
SOURCE: Grohe ladylux faucet loose on counter.
Here is the manufactures web where you may request the information you desire concerning your faucet.
http://www.groheamerica.com/s/25_4060/page/modules/iframe/index.php?if_url=http://12.130.64.173/litrequest2.htm
Posted on Dec 10, 2008
  • 111 Answers
SOURCE: Hi my Grohe kitchen sink
from underneath,may be really tricky to get a grip on you might need a basin wrench.
Posted on Jan 29, 2011
How do I tighten a loose grohe shower handle
gently so as not to break or strip the threads
Feb 07, 2015 | Grohe Plumbing
I have a wireless Grohe shower that keeps dripping hot water constantly
Your mixing valve(faucet) has a bad valve and is allowing the hot water to bypass and leak thru shower. You should replace the bad mixing valve or the faucet to repair and stop the leak.
May 10, 2011 | Grohe Home
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Hello: My Grohe Lady Lux Cafe kitchen faucet has become loose where is it attached to the sink. How do I tighten it back up? David
You'll have to go under the sink and look up were the faucet comes through. You'll see it's held in place by a large nut. This nut needs to be tightened. Unfortunately working in the tight space under the sink is a pain in the ****, just be patient and you should be able to tighten it. TIP: Have someone hold the faucet on top in the position you want it.
Feb 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
Jun 28, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe ladylux plus is leaking
I believe there is a cartrige that has some washers in the unit. There may be some debris caught in there since it was a little loose. I would turn the water off and disassymble the unit and replace any obvious washers and clean everthing up. Replace it all and try it again. If it still leaks, contact Grohe for more trouble shooting. Faucets have fantastic warranties and companies usually will send replacement parts free of charge at times. Hope this helps.
Apr 06, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe bath faucet adjustments
grohe is a faucet all by itself ,,, I would recomend to have you call there repair dept. and explain this to them, you said you put in the new cartridge and thats about all there is to it, when you put on the handle make sure it is not over tightened, sometimes it pulls on the cartridge and makes it come on by itself good luck
Feb 21, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe trim pressure balance valve
i looked at it and there might be a press in cap with a screw underneath where the grohe label is. there also may be a set screw around the shoulder of the handle where an allen hex wrench fits to losen its clamp on the stem. also.......some handles just snap on and just pull off with some tugging and wiggling them just right.
Jan 19, 2009 | Plumbing
Plumbing Logo
143 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
