Question about Toshiba TZ55V61 55" Rear Projection Television
My TZ55V61 turns on but the screen goes out. The sound still works. Sometimes the screen doesn't come on when the tv is turned on. Is it the bulb or the part that makes the bulb come on???
  • 3 more comments
  • ford_guy1965 Oct 05, 2010
    Which board is the video board? It's just the screen that goes out. Everything else works. One tv shop said it was the lamp.... he was going to charge me 300 for the lamp and 300 for the labor. So, ya think it's one of the boards instead? I guess if that is true or close to it I just need to figure out which board is the vid board and which is the tv board. That would help... Thanks
    Ok thank you. Could you include a lamp part number? There are just one lamp right?
  • ford_guy1965 Oct 06, 2010
    Thanks Tim. I think once I get the Lamp # I will be good. Let me know.. You are being a great help.
    Thank you!!!! Was Ballast!! Re-soldered the board and works GREAT!! TIM, Yur Awsome!!!
    Works great after board was looked over. Thanks Tim (micromatikal)
    President:
  • 2,777 Answers
It's the part that makes the board come on, either the Main Board of the TV or the Video Board... could be either unfortunately, no way to tell unless you inspect them and see physical damage. If they both look fine try the video board first, then the main board. It is a very difficult repair either way, I suggest you take it to a TV shop if you have no idea how to do it.
Thanks
Tim
Posted on Oct 05, 2010
  • 2 more comments
  • Tim Grayson
    Tim Grayson Oct 05, 2010
    I suppose it could also be the lamp... Thats the problem with an issue like this is that many things can cause it, but if you get no picture at all its probably the video board. Give me a bit here and I will find the part number of the board so you can identify it.
    Tim
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    The part number for the video board is 23783152, still looking for the lamp.
    Tim
  • Tim Grayson
    It actually looks like it wouldn't be the lamp, but the lamp ballast, which is part # 23122468
  • Tim Grayson
    Awesome!!! Thanks for the kind words! If possible please come back to the question here and click the Accept
    This Solution button, otherwise I don't get credit for the help
    provided.
    Thank you so much,
    Tim
I have a sony KP5375 TV and the screen flashed and went dark. Now it won't turn on and there is a electrical smell coming from the TV. Reset doesn't work. Does this sound like it is more th
yes bulbs dont smell unless they pop plus its 3 bulbs in there, plus the tv would still have power/standby lights, and it's not that type of smell, replace the bulb but im sure this will not fix the problem, also my experience with dlp set it is often not worth repair, good luck you need more help or question just ask good luck
Mar 30, 2013 | Sony KP-53S75 53" Rear Projection...
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
My LG Lcd tv takes a minute or so to turn on then sometimes the picture flickers and goes out. The tv is on but no picture or sound. When I try to use the menu button on the tv it doesn't work. Whe
The fact that you have no menu or onscreen display, leads me to believe that it is the main logic board. Either the processor ic or the voltages going to the main board are missing. Check to see if the main board is getting 5v and 3.3v to determine if it is your power supply not supplying the voltages or your main board.
Oct 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Sound with black screen
u may have a cc on , close caption , try with a universal remote and press the cc botton till it said off , otherwise u going to need a original remote
Apr 19, 2010 | Toshiba TZ55V61 55" Rear Projection...
My screen ripped i need to replace it where can i perchase one for my toshiba model # tz55v61
I own this TV and it no longer works. I am willing to sell the screen. Please contact me at ljtebbe@gmail.com
Feb 10, 2010 | Toshiba TZ55V61 55" Rear Projection...
Generic problem for all Flat Panel Televisions Plasma TV turns on
if I were you I would move the TV to a place where it would get more air to the vents of the TV so the heat buildup would be less.
Jan 10, 2010 | Maxent MX-42V1 42 in. Plasma Television
TV turns off/on
remove the bulb,(very easy to do just follow directions in the manual). On the top and bottom of the lamp there is a fine mesh screen. mine was plugged with dust. I used a vaccuum hose to remove the dirt, replaced the lamp and the tv now works.I found this remedy at a site but can't remember where (crs syndrome). saved me a $200 service call.
Jan 26, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Jun 16, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Open Questions:
Toshiba TZ55V61 55" Rear Projection Television Logo
191 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
