Question about Hitachi 43UWX10B 43" Rear Projection Television
Mitsubishi personal code entry
Hey guys...
I have a question. I have a rear projection mitsubishi model number vs5004r and she keeps telling me i need a personal code. I am using my cable remote through hughes direct tv and identified the power control. now, im trying to enter a code, but cant. If i can be helped i will sing ur praises thru dayton ohio. thanks in advance of your reply.
Mitsubishi vs5004r need code(10 digit)
Posted on Jul 23, 2008
Forgot personal code i need to reset inorder for tv to work
Call Mitsubishi customer service first---to research this I would need the correct model number
Nov 04, 2012 | Mitsubishi Televison & Video
The picture is shifted slightly left. This is really obvious when set at narrow format - the grey bar on the left is thinner than the bar on the right
you may want to download a free manual for your exact model.
All Mitsubishi sets have 3 hidden menus:
Option Menu: used mainly for a hard reset of the set.
Circuit Adjust Menu : which will have height, width, CENTERING adjustments and many others.
Convergence adjust Menu: same as in customer menu but allows save of adjustments made.
Entry into each menu is done with the original remote and a 4 digit number code.
The reason you would want the manual is it will tell you what buttons on the remote do what once you get into the (in your case) circuit adjust menu.
Some buttons will allow you to scroll the items and others to adjust them; note also on screen will be numbers indicating the current setting of each item usually with numbers. You want that so you can if you try to center picture left or right to know what original setting was in case adjusting does not help.
I have the codes for all three but confirm actual model number and get the manual so you know in your model what remote buttons do what.
Steve SD TECH
Oct 14, 2011 | Mitsubishi WS48511 48" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Green flashing light and tv wont come on
Count the number of times the light flashes. After you know that, Google your make and model number with blink codes added to the end. This will take you to sites that will tell you what the blink code on your tv means. The blink code is a self diagnostis performed by your set to tell service where to start with repairs.
Sep 12, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi projection tv (blinking green light of death) repair
Very familiar with this problem. Count the number of times the light blinks. Then, Google the make and model of your TV and add blink codes to the end. This will show you links to sites that tell you what the blink code means.
Mitsubishi vs-45605
Sure. I have had one repair person tell me it's not worth fixing. But, I am surprised that there have been no solutions posted.
James
Oct 08, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi WS-55859
Check any/all fuse devices in power supply.Let me know.....T.
By the way,the tv serial # is 107543. I assume the model # is
as stated==WS-55859.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Need pin code
I would get a generic remote and program it for your set. If you mean that you don't know the security pin which you created for the set you could have big problems. If you are talking about the factory pin, that is usually in the operation manual or you can contact the company. Generally the factory pins are simple like 1,2,3,4.
Jun 19, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
123 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
