Question about Applied Microphone Technology Amtertl '69 Buick Riviera 125 Scale Model Kit
Timing on 69 buick 350 were do marks go up down or meet in middle timing marks 69 buick lasble
    President:
  • 3,113 Answers
Posted on Nov 16, 2010
Is there a place to check the timing on a 1992 3.3 liter Buick with a timing light like you can a 350 chevy
the timing is computer controlled,the only timing marks are on the cam where the timing chain is,,check compression on all cylinders,because getting to the timing chain is a big job,its behind the water pump,here are some videos for you, 1986 cutlass 3 8L timing chain replacement
Crank Position Sensor Replacement Stalling 3800 3 8 Engine
Apr 03, 2015 | Buick Cars & Trucks
How to adjust gas gauge to read right not reading way over filled like it does now. When 1997 chev 350 vortec truck gauge is at 1 st red mark close to empty, better not past gas station ! ! !
the fuel level sender is inside the fuel tank, part of the fuel pump assembly. did you or was the tank replaced before??they may have bent the float arm on reassembly . you can buy the sender from your parts supply store .you will have to drop the tank to do this it clips onto the side of the pump assembly. run it almost dry first as the tank is big n very heavy even 1/4 full. you can try to bend the old arm
but its very hard on the "sender" as for level indicator full to empty, think of the shape of the tank narrow at top to widest point in the middle (full to half) wide middle to narrow bottom( half to empty)
its just an overall volume thing
Mar 07, 2015 | 1997 Chevrolet C1500
Timing need to be set on 76 350 Buick regal whats the degree btdc
How do you know the timing needs to be set? Check library for a repair manual. Usually the timing marks are marked on the front balancer pully mark the designated mark with something like whiteout so you can see it properly with a timing light.
Mar 05, 2015 | Buick Cars & Trucks
I have a 64 impala I want to put disc breaks in front is there a car that would enter change with it
buy it yourself cheaper Impala disc brake conversion
get rotors from
69-74 nova
70-72 monte carlo
67-72 chevelle
69-72 gto
69-72 grand prix
69-72 buick skylark
69-72 buick grand sport
69-72 buick apollo
use the bearing and seals for the car you u choose to get the rotors from
calipers
75-75 nova
73-76 monte carlo
73-76 chevelle
73-76 grand prix
73-76 GTO
73-76 tempest
must use original power brake booster from 61-64 impala
must use a master cylinder from 71-72 impala deep cup bendix part number 10-1496
71-80 gm combination valve
73 chevelle brake hoses
must buy brackets for the calipers, many places in super chevy magazine sell them cheaply!!!
Nov 01, 2014 | Cars & Trucks
What year is this engine? and ci
From this chart - I think you may be misreading the number - 3970010 is possibly the actual number: Which makes the engine pretty old 68-72 350 V8 - 4 bolt main. I included past this number so that you can see that the number you posted doesn't actually exist. And thus my conclusion that the 9 is most likely a 0. Hope this helps. 3970010 350 69 Corvette late 69,4 bolt main 3970010 302 69 Camaro Z/28,Late 69, 4 bolt main 3970010 350 69-79 Truck 2&4 bolt main 3970010 350 69-79 Pass,Chevelle,Camaro,Nova,MonteCarlo 2&4 bolt main 3970010 350 70 Corvette 300,350,370 HP 4 bolt main 3970010 350 71 Corvette 270,330 HP 4 bolt main 3970010 350 72 Corvette 200,255 HP 4 bolt main 3970014 350 69-77 Pass,Chevelle,Camaro, Nova,MonteCarlo 2 or 4 bolt main 3970014 350 69-79 Truck 2 or 4 bolt main 3970014 350 72 Corvette late &undefined;72,200 HP,255HP 4 bolt main 3970020 307 68-73 Pass,Chevelle,Camro, Nova 3970020 307 69-73 Truck 3970024 307 69-73 Pass,Chevelle,Camro, Nova,Truck 3992386 327 68-69 Pass,Chevelle,Camro, Nova,Truck Large Jounal
Oct 13, 2014 | Cars & Trucks
I have a 2002 buick rendevous and my temperature gauge goes up to the middle line when i am driving is that okay im thinking it should be down by the c
The middle or slightly below the middle mark is where the needle should be when the engine is up to operating temperature. The middle mark is about 200-220 degrees which is absolutely perfect for GM.
Jun 27, 2011 | Buick Rendezvous Cars & Trucks
Need to see digram of timeing gears on 1985 dodge slant 6
The 2 sprockets have small round marks on outside edge of pulleys, they should meet/align in middle, as in facing each other. 820ca85.jpg
Oct 17, 2010 | Dodge Pickup Cars & Trucks
When setting the timing on a 1980 chevy 350 are both gear supposed to be TDC at number 1?
Timing mark's on cam and crank should meet, if you did not put distributor out, just set timing gear's as shown, it you did pull it out, stab distributor 180 off, hope this was very helpful.
Aug 30, 2010 | Chevrolet 1500 Cars & Trucks
What do you set the timing at on a 69 chevy 350
diaconnect the vacuum advance, and loosen the distributor hold down bolt just enought so you can turn the distributor, at idle turn dist, to advance mark on the harmonic damper to spec, either found on a sticker under the hood of from manual, need a timing light, tighten dist bolt ,
May 26, 2010 | Chevrolet Impala Cars & Trucks
REPAIR MANUAL 1995 BUICK PARK AVE
THE RELAY FOR THE ABS SYSTEM IS IN THE UNDER HOOD FUSE/RELAY CENTER. IT IS LOCATED ON THE FIRE WALL UNDER A PLASTIC COVER MARKED FUSES RELAYS. THERE ARE THREE CONNECTERS HOLDING IT. ONE ON THE PASSENGER SIDE AND TWO TOWARD THE MIDDLE. THE TWO TOWARD THE MIDDLE MUST BE TURNED ONLY 1/2 TURN AND THEN THE COVER CAN BE PULLED OFF.
Jun 10, 2009 | 1995 Buick Park Avenue
Applied Microphone Technology Amtertl '69 Buick Riviera 125 Scale Model Kit Logo
97 people viewed this question
Top Applied Microphone Technology Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Applied Microphone Technology Toy Expert? Answer questions, earn points and help others
