Question about Kenmore Dryers
Why would my Kenmore Dryer Model 110C62852101 squeak when running?
5 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Posted on Jan 25, 2009
dniro592006
  • 121 Answers
SOURCE: Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
Posted on Jun 18, 2009
rylee_smith
  • 8619 Answers
SOURCE: belt squeaks on kenmore dryer
Hi
Thanks for using FixYa. Please check this video on how to replace the belt in dryer. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 20, 2010
heatman101
  • 43501 Answers
SOURCE: model 417.84082500 kenmore dryer is squeaking.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Dec 17, 2010
My dryer is an old model kenmore, model # 76692600, that has started making a terrible rattle when the dryer is running. How do I get the top off odf the dryer so I can inspect the drum motor?
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 05, 2011 | Kenmore Dryers
Whirlpool model 110.88752792 dryer runs but does not heat
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model.
I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try.
FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs.
If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
Jul 14, 2011 | Kenmore 94802 Front Load Stacked Washer /...
My kenmore gas dryer model 110-76662501 is making a thumping noise while the dryer is running. The dryer is about 5 years old used about 3 times a week. The clothes dry fine. Maybe a pulley or...
heatman101
Jul 11, 2011 | Kenmore Dryers
Kenmore dryer, model 417.84052500 make a very loud noise like metal on metal when it runs...gets worse the longer it runs
heatman101
Asker
Jan 04, 2011 | Dryers
When I run any cycle, it is squeaking and making noises. It sounds like the dryer cylinder is loose. Kenmore Elite He5t Gas Dryer
heatman101
Dec 31, 2010 | Kenmore Dryers
I have a kenmore gas dryer model 70722990 when you turn it on it has a very high pitch squeal sound runs for 5 minutes then turns it's self off and won't turn back on. can you please tell me whats going...
heatman101
Asker
Dec 27, 2010 | Kenmore Dryers
Model 417.84082500 kenmore dryer is squeaking. What do I replace?
heatman101
Dec 16, 2010 | Kenmore Dryers
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
Squeak
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Nov 29, 2009 | Kenmore 98702 Stacked Washer/Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
