Question about Maytag HYE3658AY Electric Dryer
Dryer hasn't been drying very well lately. Taking two to three cycles to completely dry. Checked exhaust pipe and it needed cleaning, very clogged. Stopped last night in the middle of a load and started smoking from inside. I unplugged it and opened the door. Everything smelled like smoke. Allowed dryer to cool off and cleaned out exhaust. Plugged in dryer this morning and does not work. No light, no drum movement. I am thinking it may be a fuse although not sure. I would like to attempt to take the back panel off to check. Any assistance would be helpful.
    President:
  • 1,554 Answers
Your instinct is right, the thermal fuse where the neutral line for the drum light and motor terminates is blown. It is located on the right hand side of the heater housing and is mounted on a bracket at the rear top of cabinet. Lift the top panel and there is a 1/4" hex-head screw that holds both the heating element bracket and the thermal fuse bracket. Remove the said screw and the thermal fuse bracket can be lifted off. The top panel can be released from the front panel by inserting a putty knife blade against the locking clips that hold them together.
Figure 1: Removing the brackets screw (thermostat removed).
Figure 2: The screw and the thermal fuse.
Figure 3: The screw removed. The thermal fuse bracket has locating tabs at the bottom and at the middle, lift the bracket to clear the tabs and remove it. Install the new thermal fuse in reverse order.
Test the continuity of the thermal fuse and replace at if no continuity along with the thermostat. You can bypass the thermal fuse for troubleshooting purposes if you don't have a tool for testing continuity. Join the wires together or jump a wire between them then insulate them properly. Plug in and start the dryer, The thermal fuse is indeed blown if the dryer runs.
Posted on Oct 05, 2010
Dryer does not dry clothes completely
If your machine is taking that long to dry. You either have a clogged vent to the outside or your gas valve coils are bad. You can check to see if it is your vent by disconnecting it for one cycle. If the unit drys in time then clean your vent. Click Here to see what a clogged vent can do. Click here to see gas valve coils.
Apr 01, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer is taking about 1 1/2 hours to dry. It still has the heating element working but no matter what setting I put it on, it is taking 91 minutes, 95 minutes to dry. Any ideas why it started to take...
How is the filter and exhaust pipe? Have you cleaned them recently? I think your machine has a clog somewhere between the filter and the outside vent hood.
Pull your machine away from the wall, remove the pipe ... if it is plastic, please consider replacing it with a metal one. Metal will not burn. Vacuum the pipe end to end - then check the flapper outside ... is it clogged? clean it.
Thanks for your interest in FixYa.com
Jun 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
My dryer heats up, but the clothes dont get dry w/o 3 full cycles
Remove the exhaust vent from the rear of the dryer. Run a timed load at 45 minutes. If it dries correctly clean your connecting vent your wall vent and the lint from inside the machine.
May 27, 2009 | Dryers
Whirlpool Gas Dryer takes 2 or 3 cycles to dry clothes
did you check ALL lines..in and out for clogs!?
Mar 15, 2009 | Dryers
Whirlpool dryer wont dry.
LONG dry time is an indication of a clogged or restricted exhaust. Check the exhaust hose in the rear of the machine and make sure it is not crushed or kinked. The vent pipe should be rigid metal not flexible foil or flexible plastic. If everything in rear looks OK, check the outside vent hood for any blockages. If everything checks out, the exhaust system may need cleaning. Cleaning kits are available at most home improvement centers and at this website:http://www.linteater.com.
Jul 05, 2008 | Whirlpool LEB6200 Electric Dryer
Dryer wont dry
LONG dry time is an indication of a clogged or restricted exhaust. Clogged or restricted exhaust is the primary cause of failure in all residential dryers. Blowing the the system with a shop vac is only a temporary solution. The system needs to be cleaned (2 to 3 times per year) with a rotary brush to scrape lint collecting from the sides of the pipe. Suggest going to Lowes and purchasing vent cleaning kit. Read instructions CAREFULLY. Also consider replacing flexible plastic or foil pipe with rigid metal type. Dryer will vent 30% to 40% better. If condition persists for too long, a high limit fuse mounted on the heater will open causing the heater to no longer operate.
May 30, 2008 | Kenmore Dryers
Help solve my dryer will not dry my clothes what can i do?
May 03, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
Maytag HYE3658AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
