Question about Whirlpool Ovens
Screen is showing an F5 code - Whirlpool Ovens
  • 2,382 Answers
Hi, here is what to do to fix your F5 error code. Move your oven away from the wall and remove the back panel (simple screws holding it in place.) Unplug your range for safety reasons. If yours is gas (and mine is) be mindful of the gas feed (mine had plenty of slack and presented no problem but worthy of mentioning.) You are looking for a part that's sort of in the 10 oclock position, it's round about the size of a quarter and held in by 2 screws. There are two wires coming into it. My part has the actual part number written on it and was the very part number I was advised to find based off the model number. You can call any appliance parts house (mine is Fox Appliance Parts in Atlanta) and give them your model number of your oven. Ask them for the part number for a "thermal fuse." They will provide the number, ship it to you or if you're local, you can pick it up. It should be around $30. Here's the cool part...you can diagnose this FIRST to see if it will fix your problem by doing this one simple thing. Remove your actual fuse by unscrewing the two screws and then slide off the two wires attached (it will slip out.) Now take the two wires still on the back of your oven and patch the two contacts together. Now plug in your oven....relax...you are merely bypassing the fuse and it will not explode or anything crazy! If the thermal fuse is your problem, your oven display will now magically reappear and the door will unlock! Now you know definitively that this is indeed your problem. Replace the part and you're back in business. You MUST replace the part though as I've been explained that it is a key safety fuse to help prevent overheating, $30 fix, even a GIRL can do it, and it takes about 10 minutes. Try it....You most likely do NOT need a new oven and do NOT need a repairman.
Posted on Oct 06, 2010
My whirlpool oven is showing an E1 F5 code. It did it once but I can't clear it now.
E1 f5 code oven - YouTube
? 1:51
https://www.youtube.com/watch?v=5F1vwVpmG9U
Dec 28, 2014 - Uploaded by Jay Dornbos
Door locked then threw the code so now the door is locked and will not open. ...Whirlpool Oven - has E1 F5 ...
Nov 23, 2016 | Whirlpool Ovens
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
Oven keeps shutting off and sais F5 on the screen
The F5 means Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
Nov 25, 2010 | GE Ovens
My ge oven model # J RSO4BOW3 is showing a error code F3 and F5
F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
Oct 30, 2010 | GE JRS04 Electric Single Oven
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Error code
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.T$%^%ETG
Dec 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore oven showing an F3 and later F5
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Nov 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirpool Super Capacity 465 Self-Cleaning Gas Range error code F5
facing the front of the oven (while off) put your hand along the back of the oven toward the top left side. there should be a techinical spec sheet with a list of what the codes mean and possable solutions.
Mar 08, 2008 | Whirlpool SB160PEE Gas Single Oven
Ovens Logo
233 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
