Question about Whirlpool GEW9250 Electric Dryer
Lights come on and makes a clicking sound when I push start.
After putting the clothes in the dryer, I set the dryer to the correct temperature and pushed start it just made a click and never started.
nitadm@yahoo.com
  • 525 Answers
Try checking your fuse box or circuit breaker panel first.The dryer requires 2-30 amp fuses to operate normally...replace both fuses instead of gussing which 1 is bad. OR, the dryer uses a double pole 30 amp circuit breaker...Flip it to OFF then back to ON. Then try your dryer and if it works you can send me flowers...just kidding! If it doesn't work, write me back and we will do some more soul searching.
Thank you for contacting us at FIXYA.com
Dave, (Illeagle)
Posted on May 29, 2008
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
I have a Kenmore Elite HE5 Electric Dryer, Model 110.8708 The dryer will not rotate when I push the start button, the "sensing revising est. time" lights up amber in the Cycle Status display...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 24, 2011 | Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Dryer won't turn
The problem is likely a slipping dryer belt. The belt tensioner is not working or the belt needs replacing.
Apr 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer quite
my dryer worked fine before xmas but washed a load of clothes and temped to put clothes in dryer and put it on right settings and pushed button to start it and nothing. We tried the breaker and shut everything down for about 5mins. and started it back up and tried the dryer again and still nothing had friend look at it and looked online and I think it maybe the start button myself.
Dec 27, 2008 | Dryers
Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
Maytag electric dryer when i set dial to desired setting i here a humming sound prior to pushing start button it has never done this before also the clothes is VERY hot when i take it out model ...
it sounds like a shorted heater element, this would also cause the heat to stay on at 110 volts which would make the clothes very hot since the element doesn't completely shut down. if it is a loud hum it could be a stuck motor switch but in this case the dryer usually won't start.
Jun 08, 2008 | Maytag Dryers
Dryer appears broken, heard LOUD sound from other room (broken belt?)
gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Apr 14, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
