Question about ASUS VW246H 24-Inch Wide 16:9 2 ms GTG Response Time 20000:1 Smart Contrast Ratio LCD Monitor
Golf mk5 gt on start up when cold i get a knocking rumbling noise only for about 3 4 minthen goes away never doesit when warm only first thing in the morning ??
    Sergeant:
    Champion:
  • 293 Answers
Loose connection in CRT board,cold solder need for resolder the power supply section.
Posted on Oct 06, 2010
Engine got a knocking cold start, silint when hot
It has developed a clicking engine noise on a cold start. After the car has warmed up, the sound goes away. ... Clicking or a sharp tapping from the valve cover on top of the engine would point to a valve train noise. A dull tapping or slapping sound from the side of the engine block would point more toward piston slap.4 Nov 2011
Cold-start engine clicking is a nuisance, not a disaster - StarTribune.com
Dec 13, 2016 | Cars & Trucks
2001 azteck 49000 miles use very little once every
The 3.4L engine has special pistons that are designed to expand as the engine heats up. When the engine is cold, the pistons make a knocking sound that resembles lifter noise or piston slap. As long as the noise goes away after the engine warms up, don't sweat it; this is normal.
Sep 17, 2014 | 2001 Pontiac Aztek
Volkswagen Golf mk5 1.6 automatic transmission 4th gear problem shifting..?
Have a pressure test done on the transmission for ban/clutch adjustment
May 25, 2013 | Volkswagen Golf Cars & Trucks
NOISE WHEN COLD THEN GOES AWAY WHEN WARMS UP,SOMEONE SAID MAIN BEARINGS GOING BAD
Hard to say over the internet but I will try to explain. If the noise is a distict KNOCK KNOCK and it sounds like it is coming from the bottom of the engine, then it most likely is a rod or main bearing. If it is a TAP TAP noise that sounds like it's coming from the top of the engine, then most likely a valve lifer is failing/failed.
the fact that it goes away when the car is warm, makes me lean towards a bad lifter. Normaly if a bearing is bad and knocking, the noise doesn't go away.
The KNOCK noise will be somewhat hollow sounding and the TAP TAP sound will be more solid. If the KNOCK KNOCK is solid, then a rod or main bearing has most likely failed to the point that a new/reman engine will be needed.
Jun 14, 2011 | 1994 Pontiac Grand Prix
I get a clunking noise from the front of my truck when I cold start it and only for a few min as is warms up then it goes away. This started in cold weather 35-60F. I have a chevy silverado 2001 1500...
this engine has forged pistons whitch expand more than hyper-u-tec-tic pistons when heated . this is normal for this engine . my brother has a chevy silverado 2001 1500 4.8Lwith 650,000 kms and he said his made that noise when it was brand new and the dealer said this is normal. the truck still runs like new with lots of power and it still makes that noise before it reaches operating temp then goes away.My brother uses lucas oil treatment and it helps quiet the knock a little when cold.
Jan 03, 2011 | 2001 Chevrolet Silverado 2500
Experiencing a "ticking" "knocking" type noise when 1st starting the car in colder weather that goes away once the blazer warms up , any help ?? I was told it could be the exhaust manifold , or piston...
it may need a lifter or valve adjustment when cold they will tick or knock depending on how loose or worn out then when it warms up they swell with heast and noise stops. after adjusting or replacing it will stop making noise
Oct 26, 2009 | 2002 Chevrolet Blazer
'96 VW Golf GL with 2.0 motor. Cold start knock
It sounds like the hydraulic lifters are bleeding down after sitting for a while... there are ball checks which are supposed to prevent this... Try using a good engine flush (a product that frees sticky lifters) and replace the oil with a good synthetic... Hope this helps...;-)
Apr 27, 2009 | 1997 Volkswagen Golf
Cold Engine Knock on 1998 Dodge Neon.
sounds like a lifter my ford f150 does the same thing when its cold but then quits when it gets warm or it could be a weak oil pump. (just some thoughts)
Feb 17, 2009 | 1998 Dodge Neon
Cold Start - 2000 VW Golf 2.0
Most likely the noise is the accessory drive belt or the timing belt.
Sep 22, 2008 | 2000 Volkswagen Golf
ASUS VW246H 24-Inch Wide 16:9 2 ms GTG Response Time 20000:1 Smart Contrast Ratio LCD Monitor  Logo
146 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
