Question about Frigidaire ATF6000ES Front Load Washer
Machine stuck on pause/err
I have a frigidaire affinity front load washer. Machine seems to be stuck on pause. any button I hit indicates 'err' light, then goes back to '31' - display minutes for load. I started, then cancelled the load because I had to add something else to it. Now won't get out of pau/err state.
Thank you very much.
  • Anonymous Mar 13, 2014
    WHAT ARE THE ERR CODES FOR A FRIGIDAIRE AFFINITY FRONT LOADING WASHING MACHINE
  • 868 Answers
Un plug the washer for 5 minutes and re try
Posted on Jun 03, 2008
I have a Kenmore washer (417.44082400), which is displaying alternately the following information: ERR LOC 37 The 37 indicates the usual minutes for our customary Permanent Press cycle. When Start is...
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have teh atf6000ES1
Pau? as in end of life? seems that perhaps the control board is speaking in a foreign language? anything happen recently to make it this unhappy?
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Won't Star keeps flashing Pause and Err
that was just happening a few seconds ago with mine and i just tried pusing the control button and the options button at the same time for a few seconds... i reopened the door and pressed start again...it's running now... good luck
Apr 20, 2008 | Frigidaire Affinity ATF7000E Front Load...
Error / Pause Affinity ATF7000
OK i had this , 2 times, take the seal off and then take the door latch off and unhook all the plugs and wait 6 min then rehook everyhting and turn it back on and wait a couple min then try
Feb 02, 2008 | Frigidaire Affinity ATF7000E Front Load...
Help me!!!!!!!!!!!!!
Ok the washer is telling you we have a problem. I will tell you how to retrieve the code and then ill tell you what that code means
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel
buttons simultaneously. As long as the buttons are
held, the failure code will appear in the display as an
E followed by two numbers, a number and a letter or
two letters. The controlwill beep and the Door Lock,
Wash, Rinse,
and Final Spin indicator lights will
flash.
Nov 16, 2007 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
1,614 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
