Question about Tappan Ovens
I have a tappan elec oven model #11-1159-10/02 with a mechanical clock that wont stop buzzing. how do I disconn the alarm.
  • 833 Answers
SOURCE: tappan oven won't turn on after cleaning
I don't precisely understand...responding. I assume that if you say oven on that the oven isn't heating but the indicator controls are working. This has several possibilities. First, do turn your circuit breakers off then on...there are two linked together. This may reset something. If that fails, your problems are likely in either the high limit safety switch or the heating elements. The elements are more likely. To check them, turn off the power and remove them from the oven. This is usually by taking out one screw and unclipping the element. See if the element is bulged or damaged. If not, use a multitester to see if one of them is not conducting. Replace it. High limit should conduct fully. Use the curcuit diagram on the stove to determine its location.
Posted on Dec 28, 2007
Powerman
  • 68 Answers
SOURCE: ge profile double wall convection oven
My solution for the F7 problem may work for you. It won't cost you anything to try it. It is simple and free. You can find it at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. You can email me at:
hutchipop@yahoo.com
Good Luck,
Powerman
Posted on Feb 04, 2008
SOURCE: problem with tappan wall mounted oven
yes, the problem is fixed thanks to repairclinic.com. those guys are awesome and there is no fee for their help. the repair parts are cheaper than anywhere else i've checked and the tech support is second to none.
Posted on Oct 12, 2008
  • 5603 Answers
SOURCE: Tappan electric wall-oven always says off ????
Check that one of the two hot wires is not losing power due to bad connection. This needs to be checked clear from the breaker to the terminal in the oven. Loss of one side of the 240 volts may still allow the clock to work as long as no other element is on.
OFTEN the connection of to the plug in the wall is bad... IT IS ALSO a fire hazard.
REMEMBER to turn off the breakers when working on this!
Posted on Aug 28, 2009
  • 84 Answers
SOURCE: Hi I have a Tappan oven model TGF357CCSF.
These controllers can be rebuild quickly and reliably. The cost is always much lower than buying a new controller. They are repaired at www.fixyourboard.com
Hope that is helpfule
Posted on May 21, 2010
Oven wont shut off
replace the switch behind the knob
Jun 27, 2012 | Tappan 30IN ELEC IGNa Oven
Need cleaning instructions for tappan self-cleaning oven model number TEF351EWE
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 24, 2011 | Tappan 30IN ELEC IGNa Oven
Aug 28, 2009 | Tappan 30IN ELEC IGNa Oven
Digital clock display
stuck keypad or bad clock may come as an assembly.
Dec 05, 2008 | Tappan 30IN ELEC IGNa Oven
Installed a new Tappan stove electric
check if there are links on the mains connector block and if so, make sure they are tight
Aug 10, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Nov 19, 2007 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
71 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Craig Butler
Craig Butler
Are you a Tappan Oven Expert? Answer questions, earn points and help others
