Question about Asko T761 Electric Dryer
Dryer cut out when in use- might have overheated- display won't work- and it won't re-start. any suggestions?
  • Asko Master
  • 2,605 Answers
Hello, Welcome to Fixya. First things first, I'd suggest you start by checking the 15amp fuses which are located at the back of your Asko dryer. **Turn off your breaker at the home service panel, it should be a 30amp switch** That is where I`d start. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color. With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part. Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown. You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, reliableparts.ca etc. Original Asko Part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble. Hope that is helpful. If so please rate the solution accordingly, if not let me know if you require further assitance. Thank`s for visiting Fixya today and good luck. Regards, Macmarkus :)
Posted on Oct 07, 2010
The dryer was drying, and suddenly stopped and control panel says call technician. Then says door open, won`t start after unplugging to reset it. The inside light stopped working at that time.
It may have overheated. Wait a couple of hours and try again. If it still doesn't work you will need an engineer to diagnose the problem. As it went out during a cycle it could be high limit thermostat or high limit cut out. Both are available on eBay and Amazon. Those parts fail if the dryer gets too hot caused by bad airflow, clogged filters, exhaust pipe or stuck vent slats outside.
Mar 16, 2016 | Frigidaire Fasg7073Lw 7.0 Cu Ft Steam Gas...
Dryer will not start. The timer works but the start button does not.
Your fuse is located on the blower housing. To get to it take the rear cover off the dryer. You will see a skinny white fuse held onto the filter blower housing by 1 screw. Note: simply replacing the fuse won't cut it. You must first find out why it melted from overheating. Remove the filter chute and look for lint. Check the outside vent.
BEFORE AND AFTER PIX
My video:
Bonus Video:
Oct 02, 2012 | Dryers
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
Kenmore dryer won't start
If thermal fuse is bad, most dryers will not run. If it is bad, dryer has overheated for some reason. Check venting to be sure it is clear and be sure heating element has not grounded out.
Aug 29, 2017 | Kenmore Dryers
Drier Shut off, won't restart. Is there a reset button?
What brand is the dryer and the model number off the machine would help greatly
May 21, 2012 | Dryers
Our 8 year old kenmore dryer won't do anything when you press the start button. We don't hear even a hum. It worked one day and then just wouldn't start the next day. We checked the fuse box...
Here is a good link for basic troubleshooting... But 10 to one the culprit is a thermal fuse or thermal cut off.... they are usually pretty cheap and easy to replace....
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
One final note on these: if you find your thermal fuse\cut off (or element) open, before replacing it, be sure to check the airflow out your dryer's vent system. Even though these devices do 'wear out' with age, poor airflow's the #1 cause of failure of these devices, and if your vent's partially clogged, a new thermal won't last very long, but will do its job again, and leave you 'cold' (a new element won't last long if the vent's clogged, either).
More info and pics:
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Jun 16, 2011 | Kenmore Dryers
My Haier HWD1600 just stopped working. I was running the dryer when it suddenly stopped. The clothes were STEAMING hot and smelled like they had been cooked. They were still mostly damp, so no fires,...
Hello Valerie
It sounds like it has overheated and the high limit thermostat has cut the power. Sometimes they will come back, sometimes they have to be replaced. There are normally two thermostats, one that happily clicks on an off during the cycle to keep the heat and what you set it and a high limit thermostat that cuts the power to prevent a fire.
Overheating is always caused by insufficient air flow. Reasons can be;
Birds nests in the exhaust pipe
Fluff build up in the pipe, particularly on bends
Vent flaps outside that don't open
Lint build up in the fan area and element area
After a quick search, I see this is a Washer - Dryer Combo machine, and furthermore a condenser dryer so all my advice above is wasted :>) You need a service engineer as it would be beyond the scope of a home repair to tear it all down.
Haier HWD1600
Haier Washer Dryer Combo Model HWD1600 Parts
Nov 12, 2017 | Haier Dryers
Won't start. The start light flashes. Timer appears to be functioning.
You could have a couple of things going on that may cause your symptoms. First of all, unplug the dryer. If you can access the inside of the dryer check to see if the dryer belt is broken. On some dryer models if the dryer belt breaks a "broken belt relay" on the idler pulley near the motor will trip causing the motor to shut down. This is to prevent a broken belt from becoming wrapped around the motor shaft. Another possibility is a blown thermal fuse or thermal cut-out. Some dryer models have a thermal fuse mounted on the exhaust vent housing and is white in color. This should read a short. There should be a thermal cut-out mounted on the heating element housing as well. There will be a hi-limit thermostat mounted near it. The thermostat will have a resistance reading (can't remember exactly what it is), and the thermal cut-out should read a short. If the thermal c/o is bad, replace the hi-limit thermostat as well. Now if you have a thermal fuse or thermal cut-out problem, they generally blow for a reason. Check your dryer ducting for proper air flow and make sure its not clogged full of lint. Normally, a thermal problem is associated with your dryer overheating. Good luck and let me know if this helps.
Jun 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Asko T761 Electric Dryer Logo
265 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
