Question about Nokia Cell Phones
How to remove the phone to insert the sim card
    President:
  • 1,118 Answers
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Posted on Oct 06, 2010
Sony xperia miro manual
Here's a link to the official user manual for Xperia Miro (http://blog.clove.co.uk/wp-content/uploads/2012/09/Sony_Xperia_Miro_Userguide_EN_ST23.pdf). On page 8 they described how to insert a microSD card into Xperia Miro.
Aug 21, 2014 | Sony Xperia miro ST23i Smartphone -...
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
S 5570 insert sim problem
help me samsung GT-S5570 insert sim card
Dec 13, 2012 | Samsung Galaxy GT-S5570
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
Insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Jun 25, 2011 | Nokia Classic 2700 Cell Phone
My samsung galaxy s keeps saying the network is unavailable and insert sim card to access network services
There are two probable causes.
1. You have inserted sim incorrectly. Remove SIM and insert properly with golden contacts facing the contacts in phone.
2. Your SIM card might be damaged. Try with another SIM card and if it works, then you have to replace your sim card.
If nothing works, you have to take your phone to some service centre
May 31, 2011 | Samsung Galaxy S GTI9000 Smartphone
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Hoe to insert/reomeve sim card?...
The position of the SIM card holder depends on your phone model. It might be placed under the battery or on the side of the phone. Before inserting/removing your SIM card, turn off your phone and make sure no charger is connected to the phone. Insert your SIM card according to the illustration that you find close to the SIM card holder.
Note: Without a SIM card, you can't make or receive calls. In some countries you can make emergency calls without a SIM card.
May 20, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
Cell Phones Logo
26 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
