Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer would not wash
Washer fills but does not wash. it spins and drains when selected
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
WOULD LOVE TO GIVE YOU AN EASY CURE,
BUT IN THIS CASE YOU WILL NEED SERVICE TO REMEDY YOUR PROBLEM!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
How do I drain my WSLP1500JWW without going through any cyles thqat fill it qwith more water? I need to drain all the water
Page 5 of your manual seems to indicate you can select spin only under wash options and press start. If other options are already selected and they won't un-select through the options menu, press the power button off and unplug the washer for a minute or two. Then replug, turn power on and retry just selecting spin only again.
Oct 28, 2013 | GE WSLP1500JWW Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Charlie
Aug 23, 2009 | Kenmore 44102 Front Load Washer
The washer will fill up with water but won't complete the cycle or drain. This has happened before, and I would spin the knob a few times and switch the load size selection. It always randomly started
it sounds like a bad timer there....! if after you selected a different load it drained......!
if it didnt drain at all on any mode I would say a bad lid swtich.
May 27, 2009 | Maytag Washing Machines
Washer stopped after wash. Would not drain or spin. Will fill.
Hi, can I get a Model# and make so I can try and assist you?
Vic
May 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Washer fills and will drain but not wash.
i remember click is the motor relay engaging.
reason for no rotation may be the motor brushes.
take back panel off, disconnect motor elec plug, undo fixing bolts and withdraw motor and you can then check brushes. also check condition of commutator - series of copper segments brushes run on
Sep 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
