Question about HP SimpleSave 1 TB USB 20 Hard Drive
Cannot access disk - HP SimpleSave 1 TB USB 20 Hard Drive
    Master:
  • 388 Answers
You need to check if the disk is spinning up if so you will need to re-mount the drive unfortunatly this will format the drive you will loose all infomation but this you can get back using a simple data rcovery program.
Posted on Oct 05, 2010
How Do I Increase My Speed
there are a few ways to increase the system performance, here's some:
1: remove any programs you don't use, this reduces the disk access time increasing performance
2:remove any toolbars or PuPs (Potentially Unwanted Programs) as these also take up disk space
3: Defragment your hard disk, think of the data stored on the disk as a messy room, the defrag tool included with yourOS will clean up and organize this mess to make the system more efficient and disk access will be significantly reduced
4:Clean up the disk, there is a nifty little tool included with your OS called disk cleanup, this will remove temporary and unused files and gets rid of things that you and the system no longer need and frees disk space, decreasing the disk access and seek timings will shorten
and the big one...5: Buy an SSD, this is a super fast disk that originates from the usb pendrive, it's faster, more energy efficient, and can store data without the need to defragment, this is an expensive way to speed up your PC, but by golly is iit worth it!!
Jan 25, 2013 | eMachines T3406 PC Desktop
Acer Extensa 5420-5038 Laptop I have access to the CMOS (via master password) but i cannot get access to the Hard Disk (also password protected) Any suggestions?
The hard disk passwords can be removed only by the manufacturer, at great cost - over $500 per disk. Unless you have really critical files that you cannot lose you should just replace the hard disk and reinstall.
May 31, 2011 | Computers & Internet
I can not access my computer after imminent failure message
> imminent failure message ... cannot access
Bad luck that the 'imminent' failure was _SO_ soon followed by _complete_ failure.
Buy a new disk-drive. Disconnect the old disk-drive.
Install Windows to the new disk-drive.
Reconnect the old disk-drive, as a 'slave' disk-drive, and hope that you can access the files on it, even though you could no longer 'boot' Windows from it.
Oct 26, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Toshiba a135 was stole can it be shotdown
Trying to locate your laptop would be like looking for a needle in a hay stack unless you know who took it.
If you had setup a power on password and a hard disk password then this would have prevented unauthorized access to the laptop and access to the data on the hard disk. Removing the hard disk and inserting it into another computer would still prevent access to the data on the hard disk without the hard disk password.
Jul 30, 2009 | Computers & Internet
Unable to access my disk with any operating system
Hey,
Seems you got a broken down drive, you can try it on another computer to see if the issue persits or take it to a computer repair shop to get it tested, no not wallmart, some real computer repair place
Thanks,
Ekse
Aug 29, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
The hard disk in drive D: is not accessible
My Toshiba lap top when i try and copy pictures to a disc it will not let me it says D:/is not accessable.incorrect function
I also tried downloading pictures from a cd and it would not read it though it did read a pdf file for documents on another disc
Mar 02, 2008 | Samsung Super-WriteMaster SE-S164L DVD?RW...
Local Disk(D:) is not accessible Access is denied
first u have format the c:drive the problem is solved
if not u should format all over the system
Feb 20, 2008 | Computers & Internet
Well this message can be two things(if not more) One of them being that the disk has security set and you wil need to change those settings if you want access to the drive the other scenario being that a program has locked the disk for exclusive access. Assuming you are using Windows XP. To check the security go to the properties of the disk then click on security(Tf the security tab isn't there, Open my computer then click Tools->Folder Options then the View Tab. Scroll to the bottom/last option then uncheck Use Simple File-Sharing press OK/Apply) Now back to Properties of the disk then Click the security tab. You'll need to try this first and tell me what's there, or if u got any error message etc. My explanation might be to long if i try to explain every possibility. regards, babb
Sep 26, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
HP SimpleSave 1 TB USB 20 Hard Drive Logo
365 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
